Wallet too big?
Discussion in 'General Discussion' started by Sapereaude, Apr 4, 2015.
  1. Sapereaude
    Sapereaude Well-known Member
    Apr 30, 2014
    191
    235
    203
    I've been doing a lot of darksend lately and my wallet has just hit 4mb, so I am wondering if I should just send it all to a new wallet now or at what size should I consider moving to a new wallet?
  2. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,637
    3,536
    50+ mb wallets can cause some slowness for qt on -reindex. 4mb should be fine.
    • Like Like x 1
  3. crowning
    crowning Well-known Member
    May 29, 2014
    1,428
    2,005
    That happens when there's too much Dash in it. Just send some over here and you'll be fine :D
    [ when my wallet got unresponsive due extensive Darksend mixing I created a new(!) receiving address and sent everything (via Coin-Control) to that single address. Seems to work so far ]
  4. yidakee
    yidakee Well-known Member
    Apr 16, 2014
    1,812
    1,168
    But if you do that, you need to remix the coins all over again. This is something to consider, wallet bloat/unresponsiveness can really be a big pain for many out there. Not only DS, but high volume tx wallets. It has been getting better on each release though...
    • Like Like x 1
  5. oblox
    oblox Well-known Member
    Aug 6, 2014
    1,032
    537
    If you DS your coins initially and sent them to a fresh address belonging to you, there is still no way to causally link you to your previous addresses since prior to that tx, it's all DS inputs.
  6. yidakee
    Apr 16, 2014
    1,812
    1,168
    Sure, but I'm not talking about covering your tracks, but to make an subsequent private tx. When you spend DS, they are un-privatized and clear again.
  7. oblox
    Aug 6, 2014
    1,032
    537
    Point being, even if you sent a non-ds tx from the new address you sent all your ds coins from, it's still private unless you've disclosed that as your address. It would show up in the blockchain like a normal, non-anon tx, but for all intensive purposes, that address just links to a ton of ds inputs. I understand what you are saying that there would no longer be a ds balance though.
  8. yidakee
    Apr 16, 2014
    1,812
    1,168
    Thats it, nothing more. Just for reference for the future, so people don't hit this thread thinking that once you mix DS, its basically anonymous, which is not the case.
    For example, you may want to support Snowden with a donation. After you mixed DS, covering your tx ID history, you consolidate your denominations into one address, and send a donation to Snowden. Obama get pissed and flags the address. One week later you completely forgot about this, and buy a USB stick through an online vendor. Alarms rings in the Oval Office, they subpoena the online vendor, your ID is revealed and you get busted.
    So the point is, if you donate to Snowden, be sure to use DS funds. :D
    • Like Like x 1
