I was going checking out Ethereum Bounty program and think we should consider something similar for Dash
This is from theyr site:
"The value of rewards paid out will vary depending on severity of impact. Rewards for minor 'harmless' bugs start at 0.05 BTC. Major bugs, for example leading to consensus issues, will be rewarded up to 5 BTC. Much higher rewards are possible (up to 25 BTC) in case of very severe vulnerabilities."
They cover
Protocol security
Implementation security
Network security
Node security
Client application security
Cryptographic primitives security
https://bounty.ethereum.org/
What do you all think ?
They cover
Protocol security
Network security
Node security
