v0.10.12.x RC4 Testing
I'm concerned about restarting the blockchain. Why did we have to do that? The reason isn't because I'm rich with over 300,000 testnet dark, LOL. But seriously, because you miss the opportunity of working with an existing blockchain. If there were any issues in starting this new version with an existing blockchain, we could have possibly caught it?
I am also concerned. I cannot get version v0.10.11.5-unk-beta to sync with new chain.
Does this mean we will have a hard fork at launch? I deleted my data folders and started with only one connection to a new node.
At least it does mean that the test blockchain was restarted at Block 0 - if a hard fork on mainnet is required needs to be confirmed by Evan. My guess is: The CheckBlock() method in RC4 is incompatible to RC3 --> hard fork. But just guessing...
I think RC4 testnet is incompatible with prior RC3.
Evan said " Note: The blockchain had to be restarted, so all of you will have to collect your test darkcoin again. Although, it's really easy to collect right now, so have at it :-) "
my log
2014-07-19 22:41:38 received block 000001128124cab4756edc387dce2b8762514916d953a4993971a40d78240978 peer=1
2014-07-19 22:41:38 SetBestChain: new best=000001128124cab4756edc387dce2b8762514916d953a4993971a40d78240978  height=10  log2_work=23.459452  tx=11  date=2014-04-28 19:20:03 progress=0.000447
2014-07-19 22:41:38 found coins 0
2014-07-19 22:41:38 DoAutomaticDenominating : No funds detected in need of denominating
2014-07-19 22:41:38 ProcessBlock: ACCEPTED
2014-07-19 22:41:38 received block 00000ce430de949c85a145b02e33ebbaed3772dc8f3d668f66edc6852c24d002 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000ce430de949c85a145b02e33ebbaed3772dc8f3d668f66edc6852c24d002  height=11  log2_work=23.584983  tx=12  date=2014-04-28 19:20:07 progress=0.000488
2014-07-19 22:41:38 received block 00000ac3a0c9df709260e41290d6902e5a4a073099f11fe8c1ce80aadc4bb331 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000ac3a0c9df709260e41290d6902e5a4a073099f11fe8c1ce80aadc4bb331  height=12  log2_work=23.70046  tx=13  date=2014-04-28 19:20:21 progress=0.000529
2014-07-19 22:41:38 received block 00000b526b34e733532d706c1f4cef93eefe707b87c2c3cb2978e1a84b97c501 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000b526b34e733532d706c1f4cef93eefe707b87c2c3cb2978e1a84b97c501  height=13  log2_work=23.807375  tx=14  date=2014-04-28 19:20:21 progress=0.000569
2014-07-19 22:41:38 received block 00000799cc6963498a215e04402737fc1a08e696a91540756b0697f1ac7b23a8 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000799cc6963498a215e04402737fc1a08e696a91540756b0697f1ac7b23a8  height=14  log2_work=23.906911  tx=15  date=2014-04-28 19:20:24 progress=0.000610
2014-07-19 22:41:38 received block 00000170cc708e9c3b491625dd8dc2d737730a738ebd349f2a770fb26944c04f peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000170cc708e9c3b491625dd8dc2d737730a738ebd349f2a770fb26944c04f  height=15  log2_work=24.000021  tx=16  date=2014-04-28 19:20:25 progress=0.000651
2014-07-19 22:41:38 received block 000000ab6ae22728c701e15a13dfa022c88f17a4e0fd71f073b0a720229de22b peer=1
2014-07-19 22:41:38 SetBestChain: new best=000000ab6ae22728c701e15a13dfa022c88f17a4e0fd71f073b0a720229de22b  height=16  log2_work=24.087482  tx=17  date=2014-04-30 19:38:20 progress=0.000691
2014-07-19 22:41:38 received block 00000541dfefddc46d4a7ef3873375db4a6f5b1c06a84b67346fb88e07f024d0 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000541dfefddc46d4a7ef3873375db4a6f5b1c06a84b67346fb88e07f024d0  height=17  log2_work=24.169944  tx=18  date=2014-07-18 15:32:31 progress=0.000732
2014-07-19 22:41:38 received block 000000d275d8dc93e7bf8c358463c97e12be9b2b17d4e64770aca7af8dcb93d8 peer=1
2014-07-19 22:41:38 SetBestChain: new best=000000d275d8dc93e7bf8c358463c97e12be9b2b17d4e64770aca7af8dcb93d8  height=18  log2_work=24.247946  tx=19  date=2014-07-18 15:32:49 progress=0.000773
2014-07-19 22:41:38 received block 0000073a769b38812ca2e3a6d4958cab3f21ed3cf4cc80590be3db4b9cb17c8a peer=1
2014-07-19 22:41:38 SetBestChain: new best=0000073a769b38812ca2e3a6d4958cab3f21ed3cf4cc80590be3db4b9cb17c8a  height=19  log2_work=24.321947  tx=20  date=2014-07-18 15:33:18 progress=0.000813
2014-07-19 22:41:38 received block 00000816a46bd5ea15161c7864b76a263f890d60d4aad6b53cceb8c39ee6b153 peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000816a46bd5ea15161c7864b76a263f890d60d4aad6b53cceb8c39ee6b153  height=20  log2_work=24.392336  tx=21  date=2014-07-18 15:33:33 progress=0.000854
2014-07-19 22:41:38 received block 00000976f999bcb32be3d5b7c2e684e8000d8566f22df2612f58b8574536addc peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000976f999bcb32be3d5b7c2e684e8000d8566f22df2612f58b8574536addc  height=21  log2_work=24.459451  tx=22  date=2014-07-18 15:33:37 progress=0.000895
2014-07-19 22:41:38 received block 00000a4f6e00f23dde0b9197d5633b1637c0c22748adadda2d1a799b26115d0d peer=1
2014-07-19 22:41:38 SetBestChain: new best=00000a4f6e00f23dde0b9197d5633b1637c0c22748adadda2d1a799b26115d0d  height=22  log2_work=24.523581  tx=23  date=2014-07-18 15:33:48 progress=0.000935
I'm having a problem, Ubuntu 64 bit 14.04, in my darkcoin.conf file I just have testnet=1 but I don't create a testnet file. Any help?
dnsseed updated, currently only 2 nodes using new protocol version (70019) available
# address                                        good  lastSuccess    %(2h)   %(8h)   %(1d)   %(7d)  %(30d)  blocks      svcs  version
184.73.179.187:19999                                1   1405807307   12.97%   3.41%   1.15%   0.17%   0.04%     466  00000003  70019 "/Satoshi:0.10.12/"
50.191.199.127:19999                                1   1405807321   12.97%   3.41%   1.15%   0.17%   0.04%     466  00000003  70019 "/Satoshi:0.9.12/"
flare I set my maxconnections=2 and add these 2 nodes, deleted my data folder and restarted. I get the same behaviour, it gets to block 18 then forks to the old chain.
dnsseeder registered 3 new nodes now
184.73.179.187:19999                                1   1405808859   24.30%   6.72%   2.29%   0.33%   0.08%     477  00000003  70019 "/Satoshi:0.10.12/"
50.191.199.127:19999                                1   1405808895   24.26%   6.71%   2.29%   0.33%   0.08%     477  00000003  70019 "/Satoshi:0.9.12/"
112.175.123.94:19999                                1   1405808862   13.03%   3.43%   1.16%   0.17%   0.04%     477  00000003  70019 "/Satoshi:0.10.12/"
the question remains, is RC4 compatible with RC3 on mainnet?
https://darkcointalk.org/threads/rc4-testing.1830/
- Darksend+ (changes outlined here: https://darkcointalk.org/threads/development-updates-july-15th.1788/)
- Masternode consessus voting spork (with enforcability, we'll switch enforcing on and test this)
- Masternode list syncing capabilities - Nodes should be able to ask and get into sync when discrepancies popup
With mainnet ? I don't know.
I'm running 10.12.0-4 with testnet=1 in the darkcoin.conf file, but I don't create a testnet folder and getinfo says I'm on block 104--- thousand something. Should I put anything else in my conf file?
When using that, it should automatically create the testnet directory. You could wipe the old one out with
rm -fr ~/.darkcoin/testnet3
Also make sure your not running an instance of Darkcoind already.
Thanks for answering, I actually cleaned everything out, deleted .darkcoin and after starting, made a new darkcoin.conf file, with rpcuser= and rpcpassword then testnet=1, that's it in the conf file, restarted and it's now downloading the main net blockchain. No testnet folder. Why do I always have a problem? Why can't I do anything correctly? LOL
I still need help, did I spell this wrong? testnet=1 ?
RC4 Testnet growing: 6 new nodes
184.73.179.196:19999                                1   1405811251   12.97%   3.41%   1.15%   0.17%   0.04%     495  00000003  70019 "/Satoshi:0.10.12/"
184.73.179.187:19999                                1   1405811251   12.97%   3.41%   1.15%   0.17%   0.04%     495  00000003  70019 "/Satoshi:0.10.12/"
184.73.179.148:19999                                1   1405811251   12.97%   3.41%   1.15%   0.17%   0.04%     495  00000003  70019 "/Satoshi:0.10.12/"
50.191.199.127:19999                                1   1405811253   12.97%   3.41%   1.15%   0.17%   0.04%     495  00000003  70019 "/Satoshi:0.9.12/"
112.175.123.94:19999                                1   1405811256   12.97%   3.41%   1.15%   0.17%   0.04%     495  00000003  70019 "/Satoshi:0.10.12/"
112.175.123.82:19999                                1   1405811276   12.97%   3.41%   1.15%   0.17%   0.04%     496  00000003  70019 "/Satoshi:0.9.12/"
Got first denominate
darktest@sv2:~/.darkcoin/testnet3> darkcoind getinfo
    "version" : 101200,
    "protocolversion" : 70019,
    "walletversion" : 60000,
    "balance" : 159.00000000,
    "blocks" : 501,
    "timeoffset" : 0,
    "connections" : 11,
    "proxy" : "",
    "difficulty" : 0.39856835,
    "testnet" : true,
    "keypoololdest" : 1405792864,
    "keypoolsize" : 1001,
    "paytxfee" : 0.00000000,
    "mininput" : 0.00001000,
    "errors" : ""
2014-07-19 23:16:19 Committing 2 changed transactions to coin database...
2014-07-19 23:16:19 SetBestChain: new best=00000001c346ffce322015052b867a0638d5cd4cf621c1c9fa3c971d90e9d361  height=500  log2_work=37.693024  tx=506  date=2014-07-19 23:16:13 progress=0.020574
2014-07-19 23:16:19 UpdatedWithin 1405811779106905, 1405810565288805 --  1
2014-07-19 23:16:19 UpdatedWithin 1405811779106918, 1405810565288805 --  1
2014-07-19 23:16:19 found coins 4
2014-07-19 23:16:19  vin nValue 400000000
2014-07-19 23:16:19  vin nValue 14700000000
2014-07-19 23:16:19 DoAutomaticDenominating : Running darksend denominate for 151 coins
2014-07-19 23:16:19  -- den 10000000000
2014-07-19 23:16:19  -- nValueRet 0, nTargetValue 15100200000, nValueRet >= nTargetValue 0
2014-07-19 23:16:19  --- nValueIn 15500000000 nTotalValue 15100200000
2014-07-19 23:16:19 CWallet::LockCoin - COutPoint(6e4445a38dfca638e06cf0522da418cbbcc540347e3cb756fb7ff8e7e05e8469, 3)
2014-07-19 23:16:19 CWallet::LockCoin - COutPoint(709dfe07613b8f2ebccaae6710bc5c247fc6cda0eec98864994f7402b48405b4, 0)
2014-07-19 23:16:19 CWallet::LockCoin - COutPoint(94371b34817f0d3fc5b8e87b59e744f4fb30e42e7acb933b64703bc0c3a555dc, 3)
2014-07-19 23:16:19 found coins 1
2014-07-19 23:16:19 keypool reserve 3
2014-07-19 23:16:19 CWallet::LockCoin - COutPoint(af0def78205c137310040e136d659f06a5782a1e89a0e0baeec748e5740663db, 3)
2014-07-19 23:16:19 CDarkSendPool::SendMoney() - Added transaction to pool.
2014-07-19 23:16:19 CDarkSendPool::SendMoney() - Is connected to masternode?.
2014-07-19 23:16:19 UpdatedWithin 1405811779114053, 1405810565288805 --  1
2014-07-19 23:16:19 UpdatedWithin 1405811779114065, 1405810565288805 --  1
2014-07-19 23:16:19 winner 0
2014-07-19 23:16:19 CDarkSendPool::ConnectToBestMasterNode - Connecting to masternode at 98.165.130.67:19999
2014-07-19 23:16:19 Found existing connection
2014-07-19 23:16:19 CDarkSendPool::UpdateState() == 2 | 2
2014-07-19 23:16:19 CDarkSendPool::SendMoney() - connected to masternode.
2014-07-19 23:16:19  -- new input CTxIn(COutPoint(6e4445a38dfca638e06cf0522da418cbbcc540347e3cb756fb7ff8e7e05e8469, 3), scriptSig=)
2014-07-19 23:16:19  -- new input CTxIn(COutPoint(709dfe07613b8f2ebccaae6710bc5c247fc6cda0eec98864994f7402b48405b4, 0), scriptSig=)
2014-07-19 23:16:19  -- new input CTxIn(COutPoint(94371b34817f0d3fc5b8e87b59e744f4fb30e42e7acb933b64703bc0c3a555dc, 3), scriptSig=)
2014-07-19 23:16:19 RelayDarkSendIn - found master, relaying message - 98.165.130.67:19999
2014-07-19 23:16:19 keypool return 3
2014-07-19 23:16:19 ProcessBlock: ACCEPTED
I really wanted to help but despite putting testnet=1 in my conf file, I get testnet = false in darkcoind getinfo. I don't know what else to do and I have to go. It's weird I'm the only one with this problem again. I'm using an almost new installation of Ubuntu that has compiled the cpuminer on it, and all that entails and that's about it, so maybe I'm missing something? But I have to go, sorry I can't help. Can't even mine, no address to put it in. Oh well...
I kept trying anyway because I'm OCD and took off everything except testnet=1 in the config file, and though my wallet crashed, it did create a testnet3 folder. Then, I restarted it again, it crashed, and started it again, and finally, it shows as 8 hours behind and is loading, so I suspect I finally got into testnet 3. Not sure why this is happening, but if anyone else has this happen, please don't be shy, report it as it might be a glitch in the code.
And in case it matters, I was stuck on downloading at somewhere like block 34000 on mainnet
compile error with msys-mingw64 in main.cpp function GetMasternodeRank
uint isn't a defined type, had to change to unsigned int
Same for me:
src/main.cpp:5836:22: error: ‘uint’ was not declared in this scope
src/main.cpp:5836:33: error: template argument 1 is invalid
src/main.cpp:5836:35: error: template argument 1 is invalid
src/main.cpp:5836:35: error: template argument 2 is invalid
src/main.cpp:5836:56: error: invalid type in declaration before ‘;’ token
src/main.cpp:5848:29: error: request for member ‘push_back’ in ‘vecMasternodeScores’, which is of non-class type ‘int’
src/main.cpp:5851:30: error: request for member ‘rbegin’ in ‘vecMasternodeScores’, which is of non-class type ‘int’
src/main.cpp:5851:60: error: request for member ‘rend’ in ‘vecMasternodeScores’, which is of non-class type ‘int’
This fixed the error
@@ -5833,7 +5833,7 @@ int CDarkSendPool::GetCurrentMasterNode(int mod, int64 nBlockHeight)
int CDarkSendPool::GetMasternodeRank(CTxIn& vin, int mod)
-    std::vector<pair<uint, CTxIn> > vecMasternodeScores;
+    std::vector<pair<unsigned int, CTxIn> > vecMasternodeScores;
     BOOST_FOREACH(CMasterNode mn, darkSendMasterNodes) {
         mn.Check();
@@ -5849,9 +5849,9 @@ int CDarkSendPool::GetMasternodeRank(CTxIn& vin, int mod)
     sort(vecMasternodeScores.rbegin(), vecMasternodeScores.rend(), CompareValueOnly());
     unsigned int rank = 0;
-    BOOST_FOREACH (PAIRTYPE(uint, CTxIn)& s, vecMasternodeScores){
+    BOOST_FOREACH (PAIRTYPE(unsigned int, CTxIn)& s, vecMasternodeScores){
         rank++;
         if(s.second == vin) return rank;
Thanks for the fix!
eta on this? - keen to get everything going on my end :)
Thanks!
Here you are:
http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-58/gitian-win-darkcoin-bin/32/darkcoin-qt.exe
