Stuck Transaction
1729taxi
I sent some Dash from Dash-Wallet. The status has shown Processing for two days now. The Address showing on the transaction is correct. There is no Txid and the Fee says 0 (not sure why!). It has not shown up in the other wallet. Is there anyway to unsend it? Reverse it? Push it on through? Add a fee if that is why it is not getting processed? I searched the sent to address on the blockchain and nothing... Looking for some help and also understanding. Thanks!
If not, sometimes transactions just go 'astray', in which case use:
Menu > Tools > Wallet > Recover transactions 1
GNULinuxGuy, Thanks for the info. Your assessment does appear to be the case. Thankfully it was just a few bucks I was just trying it out. Valuable lesson learned. The wallet I was sending from was Dash-wallet. I opened a Jaxx wallet. Ok?? It is on the dash page. I am new to Dash and just trying it out. Unfortunate experience so far. I have mostly Bitcoin.
oh man
lucky you - dash wallet is a known scam !
yes jaxx is good and trusted !
Not tried Jaxx and can only really recommend the official wallet but they're active in the community and their wallet gets good reports (iphone support!).
So glad you're actually using a trusted wallet! The hyphenated part of your post made me fear the worst. The DASH support in Jaxx is quite new, so it wouldn't surprise me if there are a few bugs in it at this point.
I would check their FAQ for any clues as to how you can deal with this problem. https://decentral.zendesk.com/hc/en-us/categories/202644577-Jaxx-FAQ If you don't see anything there that's helpful then click "Submit a request" in the upper right. I'm sure they will be happy to help. Best of luck, and thank you for using DASH! :)
