Stratum-pool vardiff config
Discussion in 'Questions and Help' started by xornemisis, Mar 7, 2015.
  1. xornemisis
    xornemisis New Member
    Mar 7, 2015
    7
    Hi All,
    I have setup a new darkcoin mining pool. However, I need assistance with setting the min and max vardiff. I am testing the pool in maintenance mode with 2MB.
    Here is the current config.py in the stratum settings.
    # ******************** Pool Difficulty Settings *********************
    VDIFF_X2_TYPE = True # Powers of 2 e.g. 2,4,8,16,32,64,128,256,512,1024
    VDIFF_FLOAT = False # Use float difficulty
    # Pool Target (Base Difficulty)
    POOL_TARGET = 0.001 # Pool-wide difficulty target int >= 1
    # Variable Difficulty Enable
    VARIABLE_DIFF = True # Master variable difficulty enable
    # Variable diff tuning variables
    #VARDIFF will start at the POOL_TARGET. It can go as low as the VDIFF_MIN and as high as min(VDIFF_MAX or coindaemons difficulty)
    USE_COINDAEMON_DIFF = False # Set the maximum difficulty to the coindaemon difficulty.
    DIFF_UPDATE_FREQUENCY = 86400 # How often to check coindaemon difficulty. Should be less than coin difficulty retarget time
    VDIFF_MIN_TARGET = 0.001 # Minimum target difficulty
    VDIFF_MAX_TARGET = 1 # Maximum target difficulty
    VDIFF_TARGET_TIME = 15 # Target time per share (i.e. try to get 1 share per this many seconds)
    VDIFF_RETARGET_TIME = 120 # How often the miners difficulty changes if appropriate
    VDIFF_VARIANCE_PERCENT = 30 # Allow average time to very this % from target without retarget
    Any help would be most appreciated.
  2. eth1
    eth1 Member
    Jul 1, 2014
    40
    64
    Greetings,
    Back when we ran our pool, we had those settings going:
    diff: 0.010,
    vardiff minimum: 0.007,
    vardiff maximum: 0.01,
    That should do the trick :)
    • Like Like x 3
  3. xornemisis
    Mar 7, 2015
    7
    Thank you! I will give it a try and see how I go...
    • Like Like x 1
  4. xornemisis
    Mar 7, 2015
    7
    hey!
    Ok I have now setup the below config as per requested.
    POOL_TARGET = 0.010 # Pool-wide difficulty target int >= 1
    VDIFF_MIN_TARGET = 0.007 # Minimum target difficulty
    VDIFF_MAX_TARGET = 0.01 # Maximum target difficulty
    Here are the results in the pool status after mining. It appears the 2MB hash is displayed as 9.4 - 10 KH/s.
    We are still not quite there any thoughts?
    [​IMG]
  5. HashWix
    HashWix New Member
    Dec 26, 2014
    21
    Not thinking it is varDiff... Shares are not being multiplied by 256 by the pool server so that MPOS can display the proper Hashrate?
    From NOMP MPOS config:
    "mposDiffMultiplier": 256, //only for x11 coins in mpos mode, set to 256
    For the python stratum mining pool server (you are using,) am not sure. Have you set both pool server and MPOS configs for x11 algo?
    Looks like your miner hashrate is 256x more that what MPOS is displaying...
  6. eth1
    eth1 Member
    Jul 1, 2014
    40
    64
    Since you are using stratum-mining I would invite you to setup NOMP and to enable the x11 diff multiplier.
    Stratum-mining is deprecated and never worked well with X11 for me and you would need to modify it to multiply the shares at the python-stratum levell; you'd be much better off with NOMP.
    • Like Like x 1
  7. xornemisis
    Mar 7, 2015
    7
  8. HashWix
    HashWix New Member
    Dec 26, 2014
    21
