sentinel doesn't think my MN is synched
drakee
25
13
Denver, CO
wolfgirl.bandcamp.com
Hello fellow masternoders! I updated my masternodes to 12.1 and am following the instructions on:
https://www.dash.org/forum/threads/taos-masternode-setup-guide-for-dummies-updated-for-12-1.2680/
However, when I run:
I always get the message:
dashd not synced with network! Awaiting full sync before running Sentinel.
But, my masternodes are synched with the network, as far as I can tell. I thought the message might go away after a while, but no luck. Am I doing something wrong?
EDIT: It looks like a couple of my MNs are finally showing no output after running sentinel.py (which is good, yes?). So maybe I just needed to wait a few hours to stop getting the "not synched" message... I will keep my eye on the remaining MNs to see if they follow suit. Thanks for reading!
Balych
365
211
Did you check with dash-cli mnsync status command?
./dash-cli mnsync status
"AssetID": 999,
"Attempt": 0,
"IsBlockchainSynced": true,
"IsMasternodeListSynced": true,
"IsWinnersListSynced": true,
"IsSynced": true,
"IsFailed": false
drakee
25
13
Denver, CO
"AssetID": 999,
"Attempt": 0,
"IsSynced": true,
"IsFailed": false
Thanks for the reply! I ran the mnsync command and got the output above for my 2 MNs that are showing no complaints from sentinel.py.
For the ones that are still complaining that they are not in sync, I get:
  "AssetID": 4,
  "AssetName": "MASTERNODE_SYNC_GOVERNANCE",
  "Attempt": 29,
  "IsSynced": false,
  "IsFailed": false
nmarley
Jun 28, 2014
369
427
Close to what @Balych recommended, this is actually checking the output of dash-cli masternode status. What is the output of that command?
EDIT: Actually, I mis-spoke. Sentinel checks both, but this part is actually checking mnsync status, exactly as @Balych described. Somewhere else it checks masternode status. If neither of them is showing correct, up-to-date MN statuses, then Sentinel will not work properly.
drakee
25
13
Denver, CO
Thanks nmarley! My masternodes seem to think they are running fine:
"status": "Masternode successfully started"
Because 2 of my MNs eventually started showing no complaints from sentinel.py, with no actions on my part, I am inclined to think that the rest of my MNs just need some time to start working (just an uneducated guess - I am new to this sentinel stuff, and I don't totally understand its function).
Maybe the root of this issue is that I'm seeing both:
and
"IsSynced": false,
from the mnsync command. I guess one can be true while the other is false - what is the difference between these two statuses?
3,639
3,537
It's a known issue, we are working on it. Don't worry, your mn is fine while spork14 is still off.
