In Russia, the tariff for electricity is cheaper at night.
The essential difference between the peak rates [7-00 - 10-00, 17-00 - 21-00], half-peak [10-00 - 17-00, 21-00 - 23-00] and night [23-00 - 7-00].
We can use rtc module to wakeup the computer. You can check it so.
Check
Turn off the computer.
After a few minutes it will start again.
So, sgminer start work at 23.00 (for cron) => /etc/cron.d/sgminer
This makes this line of code.
When morning comes, the script sets the time when the computer is turned on. And off it.
https://github.com/poiuty/Simple/blob/master/wakeup/control.php
https://github.com/poiuty/Simple/blob/master/wakeup/sgminer
http://goo.gl/qYBew4
peak 4.92 rub. / kWh
night 1.26 rub. / kWh
half-peak 4.08 rub. / kWh
echo `date '+%s' -d '+ 5 minutes'` > /sys/class/rtc/rtc0/wakealarm
Check
# cat /sys/class/rtc/rtc0/wakealarm
1426786194
# cat /proc/driver/rtc
rtc_time : 17:25:03
rtc_date : 2015-03-19
alrm_time : 17:29:54
alrm_date : 2015-03-19
alarm_IRQ : yes
alrm_pending : no
update IRQ enabled : no
periodic IRQ enabled : no
periodic IRQ frequency : 1024
max user IRQ frequency : 64
24hr : yes
periodic_IRQ : no
update_IRQ : no
HPET_emulated : yes
BCD : yes
DST_enable : no
periodic_freq : 1024
batt_status : okay
shutdown -h now
*/10 * * * * root cd /root/status/ && ./control.php
if(($hour >= 23 || $hour < 7) && check_sgminer() == 'no') shell_exec("cd /root/v5/ && screen -dmS mine /root/v5/start.sh > /dev/null 2>/dev/null &");
if($hour >= 7 && $hour < 23 && check_sgminer() == 'yes'){
$time = new DateTime(date("F j, Y, 22:55", time()));
if(time() > $time->getTimestamp()+60*10){
$time = new DateTime(date("F j, Y, 22:55", strtotime('+1 day')));
shell_exec("echo '".$time->getTimestamp()."' > /sys/class/rtc/rtc0/wakealarm");
sleep(5);
shell_exec("shutdown -h now");
