Pool not responding
Discussion in 'Questions and Help' started by fileto, Apr 5, 2015.
  1. fileto
    fileto New Member
    Apr 2, 2014
    18
    Hi guys , I stopped mining for a couple of months (dont know exactly how much) and when i decided to fire up my rigs again , i discovered that dark is now dash , ok , updated my wallet, started sgminer , and I am mining again , but i noticed that I am getting this:
    Did something change with the configuration , since dark is now dash?
    This is my .conf file:
    "pools" : [
         "url" : "stratum+tcp://mining.darkcointalk.org:3333",
         "user" : "",
         "pass" : ""
    "intensity" : "19",
    "vectors" : "1",
    "worksize" : "256",
    "kernel" : "darkcoin",
    "lookup-gap" : "2",
    "thread-concurrency" : "20481",
    "gpu-engine" : "975",
    "gpu-fan" : "75-100",
    "gpu-memclock" : "1450",
    "gpu-powertune" : "10",
    "temp-cutoff" : "92",
    "temp-overheat" : "90",
    "temp-target" : "80",
    "auto-fan" : true,
    "expiry" : "120",
    "failover-only" : true,
    "gpu-dyninterval" : "7",
    "gpu-threads" : "1",
    "log" : "1",
    "no-pool-disable" : true,
    "no-submit-stale" : true,
    "queue" : "0",
    "scan-time" : "10",
    "scrypt" : true,
    "temp-hysteresis" : "3",
    "shares" : "0",
    "kernel-path" : "/usr/local/bin"
  2. fileto
    fileto New Member
    Apr 2, 2014
    18
    No one? :(
  3. moli
    moli Grizzled Member
    Aug 5, 2014
    3,261
    1,837
    Did you change the name of darkcoin.conf to dash.conf?
  4. fileto
    fileto New Member
    Apr 2, 2014
    18
    In the \AppData\Roaming\Dash ? Yes, i have dash.conf there.
  5. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
    Would you like to try mining on p2pool ?
    If yes, please try using your address as User with any password and change url to one of following address
    stratum+tcp://p2pool.dashninja.pl:7903 (France)
    stratum+tcp://103.13.228.168:7903 (Thailand)
    stratum+tcp://dash.p2pools.us:7903 (us)
    stratum+tcp://eu.p2pool.pl:7903
    stratum+tcp://dash01.p2poolmining.us:7903 - Miami
    stratum+tcp://dash02.p2poolmining.us:7903 - Seattle
    stratum+tcp://dash03.p2poolmining.us:7903 - Chicago
    stratum+tcp://dash04.p2poolmining.us:7903 - Los Angeles
    Please let me know if you have any questions.
  6. fileto
    fileto New Member
    Apr 2, 2014
    18
    I updated my miner to sgminer v 5.1 and now I am getting: [​IMG]
  7. Sub-Ether
    Sub-Ether Well-known Member
    Mar 31, 2014
    1,516
    1,254
    I have had that happen a few times and never quite nailed what the problem was.
    What has triggered it:-
    1) opening another mining instance on a separate GPU/worker (restarting instances usually sorts this)
    2) changing to another version sgminer
    3) updating graphics drivers
    Possible solutions
    1) Download a different version of sgminer such as sgminer_x11x13mod_03_06_2014 or sgminer-5.0-pre-release-2014-07-20-win32
    2) Go back to an earlier version of your graphics drivers, for AMD, try amd-catalyst-14.7-rc3
    3) try x11mod instead of darkcoin-mod
    4) adding this in your config: "no-extranonce" : true
    5) try a smaller work size, I find 64 is best
    6) delete all your old .bins and create new ones and start from there, only add wolf0's .bins at end if all is working.
    7) copy a working sgminer folder or specific .bin from another machine and using that if compatible (good one when all else fails!)
  8. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    I just saw you are using the old out of date darkcoin kernal instead of darkcoin-mod and your config is overly complicated, start simple and add later, most settings max out anyway. (make sure your graphics card is device 0, it might be 1!)
    "pools" : [
    "user" : "flossy.1",
    "pass" : "x"
    "xintensity" : "1000",
    "device" : "0",
    "vector" : "1",
    "gpu-powertune" : "20",
    "worksize" : "64",
    "kernel" : "darkcoin-mod",
    "no-extranonce" : true,
    "lookup-gap" : "2",
    "gpu-threads" : "1"
  9. moli
    Aug 5, 2014
    3,261
    1,837
    If what Sub-Ether and thelazier showed you didn't help, maybe contact Propulsion who is the owner of darkcointalk.org. You can also ask on IRC freenode channel #dashpay. I'm sure someone there will be glad to help you out.
  10. Propulsion
    Propulsion The buck stops here.
    Feb 26, 2014
    1,008
    467
    Dash Address:
    Hi.
    Did you ever get this issue resolved? If not, PM me.
    fileto
