- Apr 9, 2014
- 8,902
- 6,729
- 1,283
Accepted your request, thanks for joining!Aloha!I have done a request to do some translate to italian language. My transifex username is the same here: kointrend. Thank you!
German is almost ready, just 100 more translations to do
Found english source error:German is almost ready, just 100 more translations to do
Will most probably have finished it end of today/tomorrow.
The new v12 translations are almost all very technical, so (for this version) I wouldn't recommend this for beginners.
German is almost ready, just 100 more translations to do![]()
Many languages though still have lots of translations like "pick suggestion, fix few symbols, done". So everyone is welcome anyway, every bit helpsGerman is almost ready, just 100 more translations to do
German is finishedI just prepared fresh version of eng source https://github.com/dashpay/dash/pull/469 and already pushed it to transifex https://www.transifex.com/projects/p/dash/resource/dash_ents/
What are you waiting for? GO GO GO![]()
Can not beat those GermansGerman is finished![]()
Did you rememeber count these in?I just prepared fresh version of eng source https://github.com/dashpay/dash/pull/469 and already pushed it to transifex https://www.transifex.com/projects/p/dash/resource/dash_ents/
That what should be updated when I push completed translations from transifex to github, that's the result of step 2. And we just passed step 1 now i.e. grab strings from code source and give them to translators. PatienceDid you rememeber count these in?
>>All help menu objects (cmd opt, both about) does not use latest translations, its old data there.
>>Splash screen on startup does not use latest translations.
I am going to work translations today when i feel better, last night was quite rough...
can you tell me the 100% once please (so i do NOT double hustle them)We have 5 languages 100% completed right now. Good job everyone involved!
Everyone else - don't wait till tomorrow, do this today!
Follow thecan you tell me the 100% once please (so i do NOT double hustle them)
tx
I believe we agreed to sticking to simplified Chinese as the 4 different versions of Chinese just will make this so dam complicate !? (Incl the update issue for the long run)Submitted a request for Traditional Chinese. I will try to fill in some of the gaps if I can.
Tungfa I only see two versions:I believe we agreed to sticking to simplified Chinese as the 4 different versions of Chinese just will make this so dam complicate !? (Incl the update issue for the long run)
Before we had x amount of Chinese versionsTungfa I only see two versions:
- Chinese (Taiwan) -- 73%
- Chinese (China) -- 63%
Where do you get four versions?
accepted!Submitted a request for Traditional Chinese. I will try to fill in some of the gaps if I can.
/paranoid mode onHi! have done a request to do some translate to Latvian language. My transifex username is the same here: kludzins. Thank you!
OK, great! I subscribed to the Chinese (Taiwan) one. That's actually what I meant to say in the first placeBefore we had x amount of Chinese versions
And to keep it simple we agreed on these
I've accepted your request. The DASH transifex is a new account, as we had to recreate it after vertoe left and deleted the old one.Hi,
I just asked to help with the Catalan translation... But I had an account already and I had in the catalan group. Is this transifex account new for DAsh?
best,
