no incoming connection
ALX3K
i have startet and updated some qt core. i can receive dash but i have no incoming connections. which port must i open when i w want it manually?
Port for incoming connections is 9999 though you don't really need incoming imo, should work fine with outgoing only too.
Also check your settings in Options -> Network (might want to check "Map port using UPnP" and "Allow incoming connections" checkboxes there)
