My wallet is not connecting to the Dash network
davebar96
Hello,
Since I installed the official Dash Core Wallet, I havent got a connection to the network, it sais "0 active connections to Dash network". I have already checked my Firewall, and marked it as safe. That didn´t help though. Can someBODY please help me?
David
(sorry for the overused meme, I just couldnt help myself)
chaeplin
Mar 29, 2014
749
356
Which OS do you use ? Windows ?
Is there any anti virus program ?
Check http://portquiz.net:9999 to check outgoing 9999 is open.
http://portquiz.net:9999 <--- open this link using browser.
if outgoing 9999 is ok, browser will display
Outgoing port tester
This server listens on all TCP ports, allowing you to test any outbound TCP port.
You have reached this page on port 9999.
Your network allows you to use this port. (Assuming that your network is not doing advanced traffic filtering.)
Network service: unknown
Your outgoing IP: x.x.x.x
Use dash nation slack http://dash-nation-invite.herokuapp.com
davebar96
Thanks for your answer,
Yes, I use Kaspersky. I have changed the Firewall Setting in it.
Port 9999 seems to be ok.
David
davebar96
Thanks again,
It acually had small restrictions in Kaspersky, wich I removed.
It still doesn´t work though...
