My wallet crashes almost immediatly after the flash screen
demo
3,113
263
153
Can some one help?
Here is the log file
2017-03-30 13:54:57
2017-03-30 13:54:57 Dash Core version v0.12.1.4 (2017-03-20 04:21:04 +0300)
2017-03-30 13:54:57 InitParameterInteraction: parameter interaction: -whitelistforcerelay=1 -> setting -whitelistrelay=1
2017-03-30 13:54:57 GUI: setGeometryDp: Unable to set geometry 5x13+320+145 on QWidgetWindow/'QLabelClassWindow'. Resulting geometry:  115x13+320+145 (frame: 4, 30, 4, 4, custom margin: 0, 0, 0, 0, minimum size: 0x0, maximum size: 16777215x16777215).
2017-03-30 13:54:57 GUI: registerShutdownBlockReason: GetProcAddress for ShutdownBlockReasonCreate failed
2017-03-30 13:54:59 Using BerkeleyDB version Berkeley DB 4.8.30: (April  9, 2010)
2017-03-30 13:54:59 Default data directory C:\Documents and Settings\d\Application Data\DashCore
2017-03-30 13:54:59 Using data directory C:\Documents and Settings\d\Application Data\DashCore
2017-03-30 13:54:59 Using config file C:\Documents and Settings\d\Application Data\DashCore\dash.conf
2017-03-30 13:54:59 Using at most 125 connections (2048 file descriptors available)
2017-03-30 13:54:59 Using 2 threads for script verification
2017-03-30 13:54:59 Creating backup of C:\Documents and Settings\d\Application Data\DashCore\wallet.dat -> C:\Documents and Settings\d\Application Data\DashCore\backups\wallet.dat.2017-03-30-13-54
2017-03-30 13:54:59 Old backup deleted: "C:\Documents and Settings\d\Application Data\DashCore\backups\wallet.dat.2017-02-07-16-15"
2017-03-30 13:54:59 Using wallet wallet.dat
2017-03-30 13:54:59 init message: Verifying wallet...
2017-03-30 13:54:59 CDBEnv::Open: LogDir=C:\Documents and Settings\d\Application Data\DashCore\database ErrorFile=C:\Documents and Settings\d\Application Data\DashCore\db.log
2017-03-30 13:54:59 Error: Couldn't open socket for incoming connections (socket returned error (10047))
2017-03-30 13:54:59 Bound to 0.0.0.0:9999
2017-03-30 13:54:59 Cache configuration:
2017-03-30 13:54:59 * Using 12.5MiB for block index database
2017-03-30 13:54:59 * Using 29.9MiB for chain state database
2017-03-30 13:54:59 * Using 57.6MiB for in-memory UTXO set
2017-03-30 13:54:59 init message: Loading block index...
2017-03-30 13:54:59 Opening LevelDB in C:\Documents and Settings\d\Application Data\DashCore\blocks\index
2017-03-30 13:54:59 Opened LevelDB successfully
2017-03-30 13:54:59 Using obfuscation key for C:\Documents and Settings\d\Application Data\DashCore\blocks\index: 0000000000000000
2017-03-30 13:54:59 Opening LevelDB in C:\Documents and Settings\d\Application Data\DashCore\chainstate
2017-03-30 13:54:59 Using obfuscation key for C:\Documents and Settings\d\Application Data\DashCore\chainstate: 21febd0f79573d28
2017-03-30 13:54:59 LoadBlockIndexDB: last block file = 0
2017-03-30 13:54:59 LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=0, size=0, heights=0...0, time=1970-01-01...1970-01-01)
2017-03-30 13:54:59 Checking all blk files are present...
2017-03-30 13:54:59 LoadBlockIndexDB: transaction index enabled
2017-03-30 13:54:59 LoadBlockIndexDB: address index disabled
2017-03-30 13:54:59 LoadBlockIndexDB: timestamp index disabled
2017-03-30 13:54:59 LoadBlockIndexDB: spent index disabled
2017-03-30 13:54:59 Initializing databases...
2017-03-30 13:54:59 init message: Verifying blocks...
2017-03-30 13:54:59  block index             343ms
2017-03-30 13:54:59 init message: Loading wallet...
2017-03-30 13:54:59 nKeysLeftSinceAutoBackup: 1000
2017-03-30 13:54:59 nFileVersion = 120104
2017-03-30 13:54:59 Keys: 1004 plaintext, 0 encrypted, 1004 w/ metadata, 1004 total
2017-03-30 13:54:59  wallet                  219ms
2017-03-30 13:54:59 init message: Activating best chain...
2017-03-30 13:54:59 Waiting for genesis block to be imported...
2017-03-30 13:54:59 Reindexing block file blk00000.dat...
2017-03-30 13:54:59 UpdateTip: new best=00000ffd590b1485b3caadc19b22e6379c733355108f107a430458cdf3407ab6  height=0  log2_work=20.000022  tx=1  date=2014-01-19 01:40:18 progress=0.000000  cache=0.0MiB(0tx)
2017-03-30 13:54:59 ProcessNewBlock : ACCEPTED
2017-03-30 13:54:59 Pre-allocating up to position 0x100000 in rev00000.dat
2017-03-30 13:54:59 UpdateTip: new best=000007d91d1254d60e2dd1ae580383070a4ddffa4c64c2eeb4a2f9ecc0414343  height=1  log2_work=21.000022  tx=2  date=2014-01-19 03:54:41 progress=0.000000  cache=0.0MiB(1tx)
2017-03-30 13:54:59 UpdateTip: new best=00000bafcc571ece7c5c436f887547ef41b574e10ef7cc6937873a74ef1efeae  height=2  log2_work=21.584985  tx=3  date=2014-01-19 03:54:46 progress=0.000001  cache=0.0MiB(2tx)
2017-03-30 13:54:59 UpdateTip: new best=00000269705556d97bc6d2e1a02c9b9031b2415192ed1ef820f384ce0d8de0ff  height=3  log2_work=22.000022  tx=4  date=2014-01-19 03:55:01 progress=0.000001  cache=0.0MiB(3tx)
2017-03-30 13:54:59 Using masternode config file C:\Documents and Settings\d\Application Data\DashCore\masternode.conf
2017-03-30 13:54:59 fLiteMode 0
2017-03-30 13:54:59 nInstantSendDepth 5
2017-03-30 13:54:59 PrivateSend rounds 2
2017-03-30 13:54:59 PrivateSend amount 1000
2017-03-30 13:54:59 init message: Loading masternode cache...
2017-03-30 13:54:59 Reading info from mncache.dat...
2017-03-30 13:54:59 ERROR: Read: Failed to open file C:\Documents and Settings\d\Application Data\DashCore\mncache.dat
2017-03-30 13:54:59 Missing file mncache.dat, will try to recreate
2017-03-30 13:54:59 init message: Masternode cache is empty, skipping payments and governance cache...
2017-03-30 13:54:59 init message: Loading fulfilled requests cache...
2017-03-30 13:54:59 Reading info from netfulfilled.dat...
2017-03-30 13:54:59 ERROR: Read: Failed to open file C:\Documents and Settings\d\Application Data\DashCore\netfulfilled.dat
2017-03-30 13:54:59 Missing file netfulfilled.dat, will try to recreate
2017-03-30 13:54:59 mapBlockIndex.size() = 5
2017-03-30 13:54:59 chainActive.Height() = 4
2017-03-30 13:54:59 setKeyPool.size() = 1000
2017-03-30 13:54:59 mapWallet.size() = 3
2017-03-30 13:54:59 mapAddressBook.size() = 4
2017-03-30 13:54:59 init message: Loading addresses...
2017-03-30 13:54:59 ERROR: Read: Failed to open file C:\Documents and Settings\d\Application Data\DashCore\peers.dat
2017-03-30 13:54:59 Invalid or missing peers.dat; recreating
2017-03-30 13:54:59 ERROR: Read: Failed to open file C:\Documents and Settings\d\Application Data\DashCore\banlist.dat
2017-03-30 13:54:59 Invalid or missing banlist.dat; recreating
2017-03-30 13:54:59 Loaded 0 addresses from peers.dat  0ms
3,639
3,537
Hmm...
Delete blocks/ and chainstate/ folders in data folder (the one with wallet.dat) and try again.
If it fails, create shortcut to dash-qt.exe, open its Properties and on Shortcut tab add " -debug" (no quotes, note the space) at the end of Target string. Run wallet again and post/send me debug.log
Make sure your antivirus ignores Dash data folder, or at least blocks/ folder inside of it - check setting, log entries, quarantined items.
demo
3,113
263
153
Hmm...
I unistalled dash-qt, and installed again to a different directory, and to a different %appdata% and run it under -debug.
Note that the machine is a windows xp. 32 bit. If you do not support such an operating system, could you please recomend me a ligh linux distro that is suitable for dash?
The debug file is too big, more than 15000 characters, so I post it in two parts.
017-03-30 18:57:23
2017-03-30 18:57:23 Dash Core version v0.12.1.4 (2017-03-20 04:21:04 +0300)
2017-03-30 18:57:23 InitParameterInteraction: parameter interaction: -whitelistforcerelay=1 -> setting -whitelistrelay=1
2017-03-30 18:57:24 GUI: setGeometryDp: Unable to set geometry 5x13+320+145 on QWidgetWindow/'QLabelClassWindow'. Resulting geometry:  115x13+320+145 (frame: 4, 30, 4, 4, custom margin: 0, 0, 0, 0, minimum size: 0x0, maximum size: 16777215x16777215).
2017-03-30 18:57:24 GUI: registerShutdownBlockReason: GetProcAddress for ShutdownBlockReasonCreate failed
2017-03-30 18:57:27 debug turned on:
2017-03-30 18:57:27   thread  category
2017-03-30 18:57:27 RandAddSeedPerfmon: 141360 bytes
2017-03-30 18:57:27 Using BerkeleyDB version Berkeley DB 4.8.30: (April  9, 2010)
2017-03-30 18:57:27 Default data directory C:\Documents and Settings\d\Application Data\DashCore
2017-03-30 18:57:27 Using data directory G:\DASH\d\DashCore
2017-03-30 18:57:27 Using config file G:\DASH\d\DashCore\dash.conf
2017-03-30 18:57:27 Using at most 125 connections (2048 file descriptors available)
2017-03-30 18:57:27 Using 2 threads for script verification
2017-03-30 18:57:27 scheduler thread start
2017-03-30 18:57:27 Creating backup of G:\DASH\d\DashCore\wallet.dat -> G:\DASH\d\DashCore\backups\wallet.dat.2017-03-30-18-57
2017-03-30 18:57:27 Using wallet wallet.dat
2017-03-30 18:57:27 init message: Verifying wallet...
2017-03-30 18:57:27 CDBEnv::Open: LogDir=G:\DASH\d\DashCore\database ErrorFile=G:\DASH\d\DashCore\db.log
2017-03-30 18:57:28 Error: Couldn't open socket for incoming connections (socket returned error. (10047))
2017-03-30 18:57:28 Bound to 0.0.0.0:9999
2017-03-30 18:57:28 Cache configuration:
2017-03-30 18:57:28 * Using 12.5MiB for block index database
2017-03-30 18:57:28 * Using 29.9MiB for chain state database
2017-03-30 18:57:28 * Using 57.6MiB for in-memory UTXO set
2017-03-30 18:57:28 init message: Loading block index...
2017-03-30 18:57:28 Opening LevelDB in G:\DASH\d\DashCore\blocks\index
2017-03-30 18:57:28 Opened LevelDB successfully
2017-03-30 18:57:28 Using obfuscation key for G:\DASH\d\DashCore\blocks\index: 0000000000000000
2017-03-30 18:57:28 Opening LevelDB in G:\DASH\d\DashCore\chainstate
2017-03-30 18:57:28 Using obfuscation key for G:\DASH\d\DashCore\chainstate: 753a70d381203696
2017-03-30 18:57:28 LoadBlockIndexDB: last block file = 0
2017-03-30 18:57:28 LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=1, size=314, heights=0...0, time=2014-01-19...2014-01-19)
2017-03-30 18:57:28 Checking all blk files are present...
2017-03-30 18:57:28 LoadBlockIndexDB: transaction index enabled
2017-03-30 18:57:28 LoadBlockIndexDB: address index disabled
2017-03-30 18:57:28 LoadBlockIndexDB: timestamp index disabled
2017-03-30 18:57:28 LoadBlockIndexDB: spent index disabled
2017-03-30 18:57:28 LoadBlockIndexDB: hashBestChain=00000ffd590b1485b3caadc19b22e6379c733355108f107a430458cdf3407ab6 height=0 date=2014-01-19 01:40:18 progress=0.000000
2017-03-30 18:57:28 init message: Verifying blocks...
2017-03-30 18:57:28  block index             453ms
2017-03-30 18:57:28 init message: Loading wallet...
2017-03-30 18:57:28 nKeysLeftSinceAutoBackup: 1000
2017-03-30 18:57:28 nFileVersion = 120104
2017-03-30 18:57:28 Keys: 1001 plaintext, 0 encrypted, 1001 w/ metadata, 1001 total
2017-03-30 18:57:28  wallet                  281ms
2017-03-30 18:57:28 init message: Activating best chain...
2017-03-30 18:57:28 Using masternode config file G:\DASH\d\DashCore\masternode.conf
2017-03-30 18:57:28 fLiteMode 0
2017-03-30 18:57:28 nInstantSendDepth 5
2017-03-30 18:57:28 PrivateSend rounds 2
2017-03-30 18:57:28 PrivateSend amount 1000
2017-03-30 18:57:28 init message: Loading masternode cache...
2017-03-30 18:57:28 Reading info from mncache.dat...
2017-03-30 18:57:28 ERROR: Read: Failed to open file G:\DASH\d\DashCore\mncache.dat
2017-03-30 18:57:28 Missing file mncache.dat, will try to recreate
2017-03-30 18:57:28 init message: Masternode cache is empty, skipping payments and governance cache...
2017-03-30 18:57:28 init message: Loading fulfilled requests cache...
2017-03-30 18:57:28 Reading info from netfulfilled.dat...
2017-03-30 18:57:28 ERROR: Read: Failed to open file G:\DASH\d\DashCore\netfulfilled.dat
2017-03-30 18:57:28 Missing file netfulfilled.dat, will try to recreate
2017-03-30 18:57:28 CMasternodeMan::UpdatedBlockTip -- pCurrentBlockIndex->nHeight=0
2017-03-30 18:57:28 CDarksendPool::UpdatedBlockTip -- pCurrentBlockIndex->nHeight: 0
2017-03-30 18:57:28 CMasternodePayments::UpdatedBlockTip -- pCurrentBlockIndex->nHeight=0
2017-03-30 18:57:28 CGovernanceManager::UpdatedBlockTip pCurrentBlockIndex->nHeight: 0
2017-03-30 18:57:28 mapBlockIndex.size() = 1
2017-03-30 18:57:28 chainActive.Height() = 0
2017-03-30 18:57:28 setKeyPool.size() = 1000
2017-03-30 18:57:28 mapWallet.size() = 0
2017-03-30 18:57:28 mapAddressBook.size() = 1
2017-03-30 18:57:28 init message: Loading addresses...
2017-03-30 18:57:28 ERROR: Read: Failed to open file G:\DASH\d\DashCore\peers.dat
2017-03-30 18:57:28 Invalid or missing peers.dat; recreating
2017-03-30 18:57:28 ERROR: Read: Failed to open file G:\DASH\d\DashCore\banlist.dat
2017-03-30 18:57:28 Invalid or missing banlist.dat; recreating
2017-03-30 18:57:28 Loaded 0 addresses from peers.dat  0ms
2017-03-30 18:57:28 Added connection peer=0
2017-03-30 18:57:28 dnsseed thread start
2017-03-30 18:57:28 net thread start
2017-03-30 18:57:28 Loading addresses from DNS seeds (could take a while)
2017-03-30 18:57:28 addcon thread start
2017-03-30 18:57:28 mnbcon thread start
2017-03-30 18:57:28 msghand thread start
2017-03-30 18:57:28 init message: Done loading
demo
3,113
263
153
log file continues
017-03-30 18:57:29 debug turned on:
2017-03-30 18:57:29   thread Ήηt" category
2017-03-30 18:57:29 GUI: initializeResult : Initialization result:  1
2017-03-30 18:57:29 GUI: Platform customization: "windows"
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Microsoft Authenticode(tm) Root Authority") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" () () ("Copyright (c) 1997 Microsoft Corp.", "Microsoft Time Stamping Service Root", "Microsoft Corporation")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "4a:19:d2:38:8c:82:59:1c:a5:5d:73:5f:15:5d:dc:a3" () () ("NO LIABILITY ACCEPTED, (c)97 VeriSign, Inc.", "VeriSign Time Stamping Service Root", "VeriSign, Inc.")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "3c:ce:73:d0" ("Certificado de la Clave Principal") () ("Certificado Raiz", "Certificado Propio")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "00" () () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03" ("CertRSA01") () ("ROOTCA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Autoridad Certificadora del Colegio Nacional de Correduria Publica Mexicana, A.C.") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:8b:00:00:02:7c:00:00:00:07:00:00:00:01" ("DST (UPS) RootCA") () ("United Parcel Service")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "00" ("Telekom-Control-Kommission Top 1") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "e2:43" ("A-Trust-Qual-01") () ("A-Trust-Qual-01")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:26:da" ("D-TRUST Qualified Root CA 1 2007:PN") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Hongkong Post Root CA") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "44:99:8d:3c:c0:03:27:bd:9c:76:95:b9:ea:db:ac:b5" ("e-Guven Kok Elektronik Sertifika Hizmet Saglayicisi") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "fd" ("GTE CyberTrust Root") () ("GTE CyberTrust Solutions, Inc.")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "68:c9:f4:d1:f0:6b:09:88:e8:96:9f:4f:cf:be:5c:b3" ("CA DATEV BT 01") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01:6c:1e" ("A-Trust-nQual-03") () ("A-Trust-nQual-03")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:ec" () () ("TC TrustCenter Class 4 CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:8a:00:00:02:7c:00:00:00:03:00:00:00:01" ("DST (NRF) RootCA") () ("National Retail Federation")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "72:8f:0d:4e:8f:15:4e:8a:3f:3f:d9:c5:b5:9f:a1:64" ("Gatekeeper Root CA") () ("Gatekeeper PKI")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("T\u00DCRKTRUST Elektronik \u0130\u015Flem Hizmetleri") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "27:8e" ("CCA India 2011") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "39:a2:93:e3" ("Post.Trust Root CA") () ("Post.Trust Ltd.")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "3c:c2:81:4b:00:e7:52:4d:9b:aa:47:b7:e1:61:f5:0e" ("Root CA") () ("GPKI")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:8b:00:00:02:7c:00:00:00:02:00:00:00:01" ("DST RootCA X1") () ("DSTCA X1")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Autoridad Certificadora de la Asociacion Nacional del Notariado Mexicano, A.C.") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("T\u00DCRKTRUST Elektronik Sertifika Hizmet Sa\u011Flay\u0131c\u0131s\u0131") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02:b5:00:00:02" () () ("VeriSign Individual Software Publishers CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Autoridad de Certificacion Firmaprofesional CIF A62634068") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "ba:5a:c9:4c:05:3b:92:d6:a7:b6:df:4e:d0:53:92:0d" () () ("Class 2 Public Primary Certification Authority")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "37:82:6d:48" ("Baltimore EZ by DST") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:f1" ("TC TrustCenter Time Stamping CA") () ("TC TrustCenter Time Stamping CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Buypass Class 2 CA 1") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:eb" () () ("TC TrustCenter Class 3 CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "27:80" ("CCA India 2007") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "ca:f6:c1:f5:70:e2:e9:03:6b:73:fc:06:92:1c:2a:f1" () () ("VeriSign Individual Software Publishers CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "31" () () ("Application CA G2")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01:a3" ("GTE CyberTrust Root") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "36:e5:8d:9e" ("SERVICIOS DE CERTIFICACION - A.N.C.") () ("SERVICIOS ELECTRONICOS")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "04" ("Autoridade Certificadora Raiz Brasileira") () ("Instituto Nacional de Tecnologia da Informacao - ITI")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "4c:af:73:42:1c:8e:74:02" ("EBG Elektronik Sertifika Hizmet Sa\u011Flay\u0131c\u0131s\u0131") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("Certificado Empresarial Clase-A") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "43:11:5a:96:1f:65:5a:d6:f0:33:12:fd:ed:d0:b9:75" ("Macao Post eSignTrust Root Certification Authority") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:ea" () () ("TC TrustCenter Class 2 CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:90:00:00:46:52:00:00:00:01:00:00:00:04" ("ABA.ECOM Root CA") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "43:cb:e7:9a:a4:2a:ae:56:b0:cf:7d:e7:e6:e9:2b:f6" ("eSign Imperito Primary Root CA") () ("Public Secure Services")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("AdminCA-CD-T01") () ("Certification Authorities", "Services")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "6f:1c:92:c4:53:00:41:45:ca:9f:7d:89:6f:18:23:e0" ("Primary Utility Root CA") () ("Public Secure Services")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:90:00:00:27:4b:00:00:00:01:00:00:00:04" ("Xcert EZ by DST") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02:b4:00:00:01" () () ("VeriSign Commercial Software Publishers CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "d0:1e:40:8b:00:00:77:6d:00:00:00:01:00:00:00:04" ("DST RootCA X2") () ("DSTCA X2")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "e2:48" ("A-Trust-Qual-02") () ("A-Trust-Qual-02")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02" ("Buypass Class 3 CA 1") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02" ("KISA RootCA 3") () ("Korea Certification Authority Central")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "7f:2a:f8:38:ea:d3:1b:f0:2d:e3:20:f6:eb:50:86:06" ("CA DATEV INT 01") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "e2:42" ("A-Trust-nQual-01") () ("A-Trust-nQual-01")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "e4:9e:fd:f3:3a:e8:0e:cf:a5:11:3e:19:a4:24:02:32" () () ("Class 3 Public Primary Certification Authority")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "00" ("CERTICAMARA S.A.") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "37:87:67:ac" ("Belgacom E-Trust Primary CA") () ("MTM")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02:ad:66:7e:4e:45:fe:5e:57:6f:3c:98:19:5e:dd:c0" () () ("Secure Server Certification Authority")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "3b:8e:4b:fc" ("Juur-SK") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "02:00:00:00:00:00:d6:78:b7:94:05" ("GlobalSign Root CA") () ("Root CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "01" ("CA Disig") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "00" ("A-CERT ADVANCED") () ("A-CERT Certification Service")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "00" ("IPS SERVIDORES") () ("Certificaciones")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "03:c7:8f:37:db:92:28:df:3c:bb:1a:ad:82:fa:67:10" () () ("VeriSign Commercial Software Publishers CA")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "45:f8:e0:e4:01:c5:3e:71:e6:bd:71:6d:97:9c:41:23" ("GPKIRootCA") () ("GPKI")
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "1b:d4:0e:d4:34:d1:da:15:a6:00:30:15:02:4d:a4:6c" ("SITHS CA v3") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "6b:1f:36:32:18:9d:2d:6f:db:ca:19:48:6f:d4:14:0b" ("CA DATEV STD 01") () ()
2017-03-30 18:57:29 GUI: "ReportInvalidCertificate: Payment server found an invalid certificate: " "98:96:8a" ("Staat der Nederlanden Root CA") () ()
2017-03-30 18:57:29 GUI: PaymentServer::LoadRootCAs: Loaded  332  root certificates
2017-03-30 18:57:29 GUI: TransactionTablePriv::refreshWallet
3,639
3,537
Win xp is out of support even by MS for few years already so it's kind of ok to have software not working there - some libs we rely on might already dropped their support.
I believe we already had someone having issues on win xp earlier.
I would recommend simply using Ubuntu, not sure if it qualifies for a "light distro" though.
re log: it could take a lot of posts... use http://pastebin.com/ and post the link instead or just send it to me via email [email protected]
demo
3,113
263
153
I tried yet another brand new installation
here is the log file. It seems to be a tor problem....
https://pastebin.com/nYfvNKMq
flare
2,286
2,404
Germany
Windows XP is not supported anymore --> https://github.com/bitcoin/bitcoin/issues/7681
There are also some strange, apparently random crashes on WinXP with 0.12
Reactions: UdjinM6
3,639
3,537
Could be any other thread crashing really, no real hints there unfortunately...
Given the @flare 's post I guess the best way would be to refrain from running any crypto wallets on win xp to avoid accidental crashes and loss of funds.
demo
3,113
263
153
I still have my wallet (12.058) in this machine. It crashes sometimes, but it works.
I will take a backup of my wallet.dat and install a Lubuntu in this machine.
I assume that if I copy the wallet.dat taken from a windows xp system to a Lubuntu system, it will work.
Or I hope so....
3,639
3,537
Or I hope so....
I wouldn't recommend using wallet.dat from windows machine on linux tbh, there where some incompatibilities in the past iirc which could lead to corrupted wallet.
If you still have 0.12.0.58 and can manage to start it I would advise to dump wallet into plain text file and then import it on new machine via dumpwallet/importwallet commands respectively.
andres
44
24
I think my error in my debug is because of this
2018-04-14 09:06:19 Leaving block file 17: CBlockFileInfo(blocks=14917, size=134197602, heights=645302...660253, time=2017-03-31...2017-04-27)
2018-04-14 09:06:19 Pre-allocating up to position 0x1000000 in blk00018.dat
2018-04-14 09:06:19 Unable to open file C:\Users\USER\AppData\Roaming\DashCore\blocks\blk00018.dat
2018-04-14 09:06:19 ERROR: WriteBlockToDisk: OpenBlockFile failed
2018-04-14 09:06:19 *** Failed to write block
