missing dependency: python-virtualenv
Discussion in 'Masternode Questions and Help.' started by semajjames, Nov 8, 2018.
  1. semajjames
    semajjames Member
    Feb 5, 2015
    152
    13
    78
    I'm getting "missing dependency: python-virtualenv" when using dashman to install mn on ubuntu 18 04 ,, and sentinel will not work any ideas
    also
    /home/******/dashman/lib/dashman_functions.sh: line 1129: [: too many arguments
    any ideas
  2. strophy
    strophy Administrator
    Feb 13, 2016
    571
    322
    Did you update Ubuntu recently? Python errors are common when upgrading from 16.04 to 18.04, for example. Try manually installing with "sudo apt install python-virtualenv" to see if you can resolve the dependency manually.
    • Like Like x 1
  3. semajjames
    semajjames Member
    Feb 5, 2015
    152
    13
    78
  4. strophy
    Feb 13, 2016
    571
    322
  5. TaoOfSatoshi
    TaoOfSatoshi Grizzled Member
    Linguistic Dash Nation Founder Moderator
    Jul 15, 2014
    2,623
    2,586
  6. semajjames
    semajjames Member
    Feb 5, 2015
    152
    13
    78
    indeed I have always found Tao's guide's work and are very quickly up to date ,,,,, anyway from what i have gathered here is:- in order for dashman to work on ubuntu 18 then Moo would need to do some sort of update ,,, I have there for moved back to my old VPS where i am able to run an older version of ubuntu for now
    • Like Like x 1
  7. semajjames
    semajjames Member
    Feb 5, 2015
    152
    13
    78
    ok thanks for your help guys ,,,, one more thing
    once i have done this
    Add a check function to crontab to make sure it checks every minute to ensure your masternode is still running:
    crontab -e
    Choose nano as your editor and enter the following line at the end of the file, after the line for sentinel:
    is that ALL i need to do to keep dashd running in all eventualities OR do i still need to use the restart script that starts dashd if for some reason the server restarts or dashd simply stops ?
  8. strophy
    Feb 13, 2016
    571
    322
    This should be all you need, that one line will check each minute to make sure dashd is running, and if not, it will restart it. This also works in the case of a system restart. Make sure you also have a line to run Sentinel each minute!
Share This Page
