Miner don't start
RBCastro
What can I do if everytime I try to run miner it stop responding and closes?
I make sure that I use the corresponding miner for my CPU.
Thanks.
Thanks.
Info:
OS: Windows 8
CPU: Intel Core i5-2410M - 2.30GHz
Miner: DarkCoin cpu-miner - minerd-corei7-avx.exe (v1.3)
You still haven't given us the .bat or config settings.
Btw, put a 'pause' at end of .bat file and you stay on the window.
My .bat file:
minerd-corei7-avx.exe -a X11 -o stratum+tcp://us-east.multipool.us:3371 -u XXX.X -p X -t 1
When I start the .bat file it stop work and gives me an alert window to close the program.
This is the error window (in portuguese):
I think you misunderstand how cpu mining works, you need to mine using a worker created as part of a pool of miners that work together to find dash blocks of around 6 coins (forget solo mining its too difficult to find a block)
sign up to a pool then create a worker and place the worker details inside a .bat file that is part of your minerd folder.
I sometimes use xpool, you don't even need to sign upto them, you only need to put any wallet recieving address in the .bat command
minerd-corei7-avx.exe -a x11 -o stratum+tcp://mine.xpool.ca:1131 -u 'wallet address' -p x
pause
-a = sets the kernal
you could try this software as well,
https://github.com/tpruvot/cpuminer-multi/releases
My .bat file:
Try another type of minerd.exe, your cpu may not support the i7 instructions and be careful with x11 and X11 for the 2 different miners when setting the algo and put a pause at the end.
here is a new cpu mining thread which might help :smile:
https://dashtalk.org/threads/sub-ethers-guide-to-cpu-mining.6170
