Masternode On Raspberry Pi 2 Model B
fuzzyduck
Active member
****OUTDATED****
This guide is NOT up to date with version 12.1. Besides raspberry pi builds can be downloaded from straight from the website so compiling is no longer needed.
I do not recommend the pi as a masternode just yet. I got 30 to 60mb ram left of 1gb which is next to nothing.
NOOBIES GUIDE GETTING A MASTERNODE TO RUN ON A RASPBERRY PI 2 MODEL B
UPDATE #1
Thx to user Sandell its now also confirmed its working on a Pi 1 model B(512mb ram). Not sure about stability though cuz of lack of free ram)
UPDATE #2
The guide is updated to DASH
UPDATE #3
Obsolete
UPDATE #4
Updated to V12. Not really much difference. I think i had to add 'sudo apt-get install libqt4-dev' to get dash-cli to build.
WHY?
A week, ago my Raspberry pi 2 arrived and was delighted to finally get a masternode run on it, instead of hosting it at a VPS(thx for that Flare).
It all went well and its running as i write this. With help of various people by mail and on the forums I decided to contribute to write a howto tutorial with all the new stuff i have learned.
NEEDED KNOWLEDGE?
Almost no prior knowlegde. As a windows-boy i know my way around pc's except hardcore coding n stuff. Ive been playing around in Ubuntu as well in a virtual machine just to see what it means to run a linux distro. Im classify myself as a linux noob. So if i can do it, you can do it too ;)
This guide can be written way more more compact but didnt do that on purpose for you to follow easily. I made it the most no-brainer i could.
"Like warm raspberry pi"
MY SOURCES?
I grabbed different sources to make this tut. Mainly TAO's tut for some shameless copy paste (THX!), some forum posts for the basic setup of the pi2 (THX!)
SPEED OF THE PI2?
The compiling of the needed file for the master node takes about 1.5/2h until done. The PI2 has an ARM kernel. So just downloading the 32bit/64bit version just doesnt cut it....
We have to compile it ourselfs on the PI2.
There is the possibility to crosscompile on your desktop but that is beyond the scope of this tut. In this tut We will do the 1.5h waitinggame. Compiling is long but not that long.
One you built your first, there is the possibility to leave the Masternode running while compiling the next version. That way you dont have to take it offline for long and miss your valuable DASH.
PREREQUISITES?
1. A raspberry Pi 2 model B, (duh!)
2. >1000 DASH
3. I did this on windows so its written as such
4. Unlimited data from your ISP
5. A stable highspeed internetconnection with a fixed IP address
6. Know your way around your router OR learn how to
7. SDcard class 10
8. Cardreader
9. Basic nerdskills
10. An girlfriend/wife who understands what you are doing at night and why its so awsome. (I failed at this one, girlfriend yes, understanding? Nah)/
ISP TEST (Do both tests before continuing)
Test 1:
go to whatismyipaddress.com and take note of your IP. Then pull the plug on your modem, wait a bit and replug. Check the page again. If the same then good!
Test 2:
: Take note of IP address and wait 24h and check again. If the same then good!
DISCLAIMER
Running a Masternode on a PI2 is hardly tested for a longer period of time. Besides, they just got out. Mine is running 24/7 at this moment with no issues, but i cannot guarantee yours will too. So i will take no responsibility for what ever happens to yours. As with the crypto-scene, its highy experimental! At your own risk.
DONATIONS
:rolleyes:If this tutorial has been helpful for you, dont be shy and donate some spare DASH in my pocket. Thank you! :rolleyes:
XdptGDg2mMQ7wrcp8eUDtTkSPW71vMteBF
HERE WE GO!
1. Grab gear
Take a grab in your hardware box and take out a micro SHcard class 10 and a cardreader, or buy these. These puppies are cheap so grab a large one. I got a 32gb, for lateral future use also. Even cameras take these. Be sure it fits in your cardreader, else dont forget an SD-adapter. They are usually in the package of the product.
2. Grab Operating System
Head to http://www.raspberrypi.org/downloads/ to download the latest RASPBIAN image. Unpack the file to whatever dir you like. Dont use older ones because they dont run on the PI2.
3. Flash OS to sdcard
Head to http://www.raspberrypi.org/documentation/installation/installing-images/ and follow the tutorial to get the downloaded and unpacked image (.img file) on the sdcard. I did the Windows tutorial. After you have flashed the IMG-file to the card put it in your pi2. Be gentle, its a delicate slot.
4. Booting
Hook up the Pi2 to your router with an ethernet cable. We do want a stable connection so no wifi (i tried it and worked flawlessly, but eventually i moved it to my router with a 1.5m cable, besides wifi needs tinkering with files on the PI2 and im not gonna bother you with it atm).
Then hookup it up to a powersupply (i got it running on a 1,5Amps phonecharger. Just dont go hooking all sorts of USB on it because then you might need more amps. Im using mine as a decicated mastenode box.
Your pi2 is now booting the operating system you just flashed to the SDcard.
5. Fetching the IP
On Windows press windowsbutton+R. type 'cmd' and press enter. You enter a DOS box. type IPCONFIG and press enter. Scroll up a bit till you see Standard Gateway. Take note of the IP. 99% of the time it starts with 192.168.1.xxx or 192.168.0.xxx
6. Config your router
Start your browser and enter that IP. You will now see your router's website. Enter login + password (sticker on router?)
In the menu's somewhere there is a list of connected devices. They all have a IPaddress. Take note of the one called RASPBERRY.
Somewhere in the menus of your router you can do a DHCP reservation for the IP address of the PI2. This means everytime the PI2 boots it gets the same IPaddress. Thats what we want. We dont want it to change. Dunno your router so cannot help on this one :( Check manual or do a search on it. You should find some other tut.)
Now also somewhere in the menu of the router there is a NAT or PORT FORWARD menu. Enter the IPaddress of the PI2 and open port 9999. Usally by just filling all portboxes with 9999. IN / OUT etc. Maybe you just have one box to put it in.
Save the config of the router and reboot it. (also in the menus somewhere)
You are now re-routes internet traffic on port 9999 to your Pi2.
Check http://www.yougetsignal.com/tools/open-ports/ and fill in port 9999 to find it open.
7. Putty for a terminalconnection
No head to you desktop and download putty @ www.chiark.greenend.org.uk/~sgtatham/putty/download.html. Take the top one Intel x86 is fine.
Drag it to your desktop and start it. Enter the IPaddress of the pi at the Host Name, fill Masternode or whatever at Saved Sessions and press Save. That way you can easily load it again. Press Open.
Now you see a black box with a prompt. Enter 'pi' as login and 'raspberry' as password. You then see a green with blue prompt.
8a. Setup the PI2
Now we are gonna setup the PI2 just a little bit before continuing. From now on, whenever you see a RED line then thats a command. Type it and hit enter.
sudo raspi-config
You are shown a simple menu. We are gonna do options 1 2 and 3. Use the arrows and tab to navigate.
1. Expand the filesystem so it uses the whole 32gb of the SDcard
2. Change the password of the user pi. Make a strong password like you do so your darkcoin wallet.
3. Make it boot to command-line. So that way we safe some ram by not loading the desktop enviroment we will not be using at all.
I forgot if it reboots automaticly or manually. If manual, then:
sudo reboot
Putty will give an error it has lost connection. Reopen Putty and log in again after 1min. Remember you got a new password for the user 'pi'.
8b. Change root password and change username pi
Next we change to root password to something strong as well. Choose a long one:
sudo passwd
Close putty and login with user 'root'
Change username 'pi' to your loginname
sudo usermod -l NEW -d /home/NEW -m pi
sudo chown NEW /home/NEW
Close putty and login with your new login name.
9. Download and install the needed packages
At the prompt type the following commands in this order to fully update the pi and get it ready for compiling. Press yes to all when asked.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get install libtool autotools-dev autoconf libdb-dev libminiupnpc-dev dh-autoreconf libdb++-dev libboost-all-dev libssl-dev pkg-config joe ufw protobuf-compiler libprotobuf-dev libqt4-dev
Just copy the whole thing and rightclick mouse in the putty screen. If it fails do one by one as written down here:
# sudo apt-get install libtool autotools-dev autoconf
# sudo apt-get install libdb-dev
# sudo apt-get install libminiupnpc-dev
# sudo apt-get install dh-autoreconf
# sudo apt-get install libdb++-dev
# sudo apt-get install libboost-all-dev
# sudo apt-get install libssl-dev
# sudo apt-get install pkg-config
# sudo apt-get install joe
# sudo apt-get install ufw
# sudo apt-get install protobuf-compiler libprotobuf-dev
# sudo apt-get install libqt4-dev
there is maybe one too much in the list but this does the job for sure (maybe somebody can tell me which one is not needed, I grabbed them from different tuts.)
10. Config the Firewall
We are going to configure the firewall on the PI2 you just installed to block all ports except port 22(for putty) and 9999(for masternode):
sudo ufw allow ssh/tcp
sudo ufw limit ssh/tcp
sudo ufw allow 9999/tcp
sudo ufw logging on
sudo ufw enable
Again reboot and again use putty to get back:
sudo reboot
Check your firewall's status by entering the following command:
sudo ufw status
It should say active.
11. Preparing the build
ls
You will see a directory 'python-games' which in my eyes its clutter because the directory you are seeing now is your 'home' directory we will be using. Remove the dir:
sudo rm -R python-games
We are now gonna download the newest whole 1:1 DASH source from which we will compile the file needed to run the masternode, DASHD
git clone https://github.com/darkcoin/darkcoin
(yes, its still at this address although darkcoin is rebranded to DASH
When done type check if directory darkcoin folder is there:
ls
12. Swap or crash!
CHAPTER 12 IS NO LONGER CORRECT. COMPILING WITH 1 CORE SEEMS QUICKER THEN 3. SKIP TO CHAPTER 13
Before we are gonna compile we want to make the most out of the 4core cpu on the pi. When compiling with more cores the 1gb RAM on the PI2 is not enough and the build crashes to prompt. We need a swapfile on the pi to use as RAM. 1core compiling works bswaut takes looooong. To create a swapfile of 2gb in the root dir of the pi:
sudo dd if=/dev/zero of=/root/swap bs=1M count=2048
Change the permission of the swap file so that only root can access it:
sudo chmod 600 /root/swap
Make this file as a swap file using mkswap command:
sudo mkswap /root/swap
Enable the newly created swapfile:
sudo swapon -a
Check if swap is enabled with:
top
This will show a everupdating processeslist. Look for KiB Swap at the top. It should get a high number at 'free'. Exit the command hitting CONTROL + C on keyboard.
NOTE: Enabling swap does lots of read/write on the sdcard shortening its lifespan. So only do the command when compiling on 2 or 3 cores. Swap is not needed when compiling on 1 core i think. To turn off swap:
swapoff -a
13. DA BUILD! 2 hours of teethgrinding, nailbiting, checking and rechecking
We are now gonna compile darkcoin and use just the one file called DASHD to run the masternode. Enter the directory, config the build and compile it typing subsequently:
cd darkcoin
./autogen.sh
./configure --with-incompatible-bdb
make
Go outside and do something healthy and check back in 2h.
NOTE1: This will take lots of time and gives errors about arm6 and arm7. Ignore it, let it run. Be aware that closing Putty stops the build so leave it open. ( i got a headless server running so i do it from there. You can expiriment with the command 'screen' www.tecmint.com/screen-command-examples-to-manage-linux-terminals/ but im not bothered atm. Dunno how yet).
14. Checking stuff 'n setting up
You are still in the darkcoin folder. Enter the src folder of darkcoin and check if DASHD is there with:
cd src
ls
Now we are gonna move that file to the home dir where you start everytime with putty.
mv dashd ../..
Which moves it 2 dirs up to your home dir. At this stage you should have the directory darkcoin and the file dashd in the dir. Check with:
ls
The dashd file cant be run yet so we need to make it executable:
chmod +x ./dashd
To preset some settings to make it work we make a directory called .darkcoin and enter it with:
mkdir .dash
cd .dash
NOTE: this is the workingdirectory of the masternode. Its there, but hidden.
We need to make a configfile in there with an commandprompt file-editor Joe, which you installed earlier:
joe dash.conf
Type the following in the empty editor or paste this with just a rightmousebuttonclick in the putty screen.
rpcuser=RANDOMSTRINGOFLETTERSANDNUMBERS
rpcpassword=LONGERRANDOMSTRINGOFLETTERSANDNUMBERSHAVEFUN
rpcallowip=127.0.0.1
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=256
masternode=0
masternodeprivkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
addnode=23.23.186.131
Hit CONTROL - K then CONTROL - X to save and exit Joe.
For added security, it is recommended to make this file "Read Only" so no one can change it:
chmod 444 dash.conf
NOTE1: rpcuser and rpcpassword can be anything, you DONT have to remember them later. Only use letters and numbers.
NOTE2: Check and recheck. it usually goes wrong here with a typo.
Leave the dir one up back to your home directory:
cd ..
14. Lets fire it up for the first time
Run your darkcoind daemon for the first time:
./dashd
You will see the message like "Server Starting". It will now startup and configure itself. Also it will go download the blockchain. This will take plenty of time, and only happens once. Check if files are being made with:
cd .dash
ls
(check if there is more then that config file you made earlier made)
cd ..
Fire up another putty and at prompt check its progress with:
top
The CPU is 100% all the time. When its done it is just about 10%:
When done, close the second putty and return to the first one and check stats:
./dashd getinfo
Check the blockcount and check if its the same @https://chainz.cryptoid.info/dash/ See blockheight. If its the same and cpu dashd is max 10% all the time you know its done.
15. Linking it to your local wallet on your desktop pc.
32. We are now gonna make a private key so your masternode and local wallet can talk to eachother:
dashd masternode genkey
NOTE: Dont worry, this is not a key to get to your 1000dash. They are still safe in your local wallet protected with its own privatekey.
Select the generated string with your mouse. You dont need to copy it. Dragging mouse copies it automaticly.
Stop the the masternode and enter the hidden .darkcoin directory again and edit the configfile:
./dashd stop
cd .dash
joe dash.conf
Delete the long XXXXXXX-string and paste the string with a right mousebutton click on the putty screen. Also change masternode=0 to masternode=1 and save n quit with CONTROL - K then CONTROL - X
After leave the dir again to your home directory.
cd ..
Also copy paste the string to a notepad editor on your desktop pc. We need it later.
16. Starting your masternode permanently!:grin:
Restart the deamon and wait for it to idle (remember, you can check with another putty with command 'top' remember?, again takes a bit of time)
./dashd
Useful commands to check if your masternode is running ok:
# ./dashd getinfo
Check version number and block count vs website
# ./dashd masternode debug
It should say: masternode started remotely. If anything else its NOT working ok. use this only if you end this tutorial.
./dashd masternode list | grep YOUREXTERNALIPADDRESS
Check if your ip is red and the line ends with a 1 like: "YOUREXTERNALIPADDRESS:9999" : 1. Then you know its connectes and seen on the network.
:smile: CONGRATS SO FAR! THE HARD WORK IS DONE! :smile:
17. Updating & configuring your local wallet on your desktop to get the payments rolling in
Download the latest wallet from http://www.dashpay.io/ and replace the version with the one you already have on your pc. ( I assume you already have your wallet running, else you are not here) :rolleyes:
The Local(wallet on your desktop) and Remote(Masternode on PI2) version should always be the same.
Dont start it yet. We are now gonna make another dash.conf and put it in the datadirectory of the wallet. This should be here unless you moved it on purpose:
C:\Users\username\AppData\Roaming\Dash
Now open notepad and paste this:
masternodeaddr=XXX.XXX.XXX.XXX:9999
masternode=1
Change the first XXX with you external IP address.
Change the second long XXX with your masternode private key i asked you to save somewhere.
Save the file as dash.conf in C:\Users\username\AppData\Roaming\Dash
Start up the wallet and let it sync until you see a green checkmark in the bottom right corner.
18. Moving you 1000dash to a masternode address
Unlock your wallet in the settings menu. If you dont have it encrypted yet do it NOW! :eek:
Again, choose are very strong password. Not the name of your pet, but preferably a sentence you can remember easily. Make it weird swapping a with @, s with a $ etc.
Anyway you should have it unlocked before continuing....
In the wallet head to Tools-->Debug console
Now to generate your new Masternode's receiving address type:
getaccountaddress 0
This will output your special masternode payment enabled public address!
Next up is dumping the private key of that new address:
dumpprivkey YOURADDRESCOPYPASTEIT
Copy both strings to a notepad editor and print it. Store is somewhere safe.
For now, save the notepad file to your desktop temporarily. We will encrypt it later in chapter 20.
From wherever you currently hold your 1,000dash (exchange, another dash wallet, even a different address in the same wallet), send your dash to your freshly generated "0" Masternode receiving address in your wallet. Make sure the "Darksend" checkbox is unchecked.
You must send exactly 1,000dash to this address, no more, no less, to be eligible to run a Masternode! Once you have initiated the transaction, you must wait for a minimum of 15 confirmations so your address is eligible to be associated with your new Masternode.
19. Starting your mastenode.
Now after you 15 conformations are through you can start your PI2 masternode. Again do this from the debug-console and enter:
masternode start YOURWALLETPASSWORD
You should see "successfully started masternode"
Wait about 20 to 30min and check:
https://dashninja.pl/?mnregexp=XXX.XXX.XXX.XXX
On this site you can see if your masternode is listed. Ofcourse replace the XXX with your external IP. It should be all green like this:
:smile:CONGRATS SO FAR! YOUR MASTERNODE IS RUNNING!:smile:
20. Storing your precious files to a USB
Grab a thumbdrive you can spare and empty it because you will loose all data.. Head over to
https://www.grc.com/misc/truecrypt/truecrypt.htm
and install Truecrypt 7.1a
Next follow the graphical tutorial on:
https://kb.wisc.edu/page.php?id=18301
You end up with an encrypted USBthumbdrive you can unlock with a password using truecrypt.
Save the notepad file with the public and private key to the openend USBthumbdrive. Delete the file from your desktop and empty the desktop trashcan.
Close Your Dash Wallet and wait untill its done closing. Head over to your datadir C:\Users\username\AppData\Roaming\Dash
and copy your wallet.dat and your dash.conf to your usbthumbdrive as well. Then close the drive and store the drive in the house somewhere.
<BLINK> NOTE: NEVER COPY/MOVE THE WALLET.DAT FILE WHILE YOUR WALLET IS OPEN. IT WILL GET CORRUPTED! </BLINK>
Note: You can also make a truecrypt container file and save it on your desktop but, you know.... Harddisks fail......:what: (and if you are like me, tinkering with hardware, you might just drop a screwdriver in a running pc:grin:.
Alternatively you can make that truecrypt containerfile and save that to the thumbdrive. In that way you can save some more files on it unencrypted. You choose your flavor.
Remember you can loose both the sheet of paper AND the thumbdrive by fire, if both held at home. So you can also email a containerfile to yourself with a weird name. Zip it also, again with a strong password (other one then the walletfile).
21. Updating your running masternode
NEW: 05-08-2015
I made and update script tailormade for my tutorial. Run it and its all on automatic. Only to do is type the sudo password and the beginning and ending of the script to to enable and disable swap. Make sure you did the greyed out chapter 12 in my previous post. Dunno what caused it but building a new version made the running dashd crash, so i added swap to this script.
In the dir you land when using putty type:
nano update
( If you get error you dont have nano installed: sudo apt-get install nano )
Then copy paste the whole lot down below with a rightclick.
#!/bin/sh
clear
echo " "
echo " "
echo " ******** SWAP ON, TYPE PASSWORD ******** "
echo " "
echo " "
sudo swapon -a
echo " "
echo " "
echo " ******** REMOVING BACKUP AND OLD GITHUB CLONE ******** "
echo " "
echo " "
rm dashdold
rm -R -f darkcoin
echo " "
echo " "
echo " ******** CLONING NEW GITHUB ******** "
echo " "
echo " "
echo " "
echo " "
echo " ******** STARTING BUILD ******** "
echo " "
echo " "
./darkcoin/autogen.sh
./darkcoin/configure --with-incompatible-bdb
./darkcoin/make
echo " "
echo " "
echo " ******** STOPPING DASHD AND SLEEP 20SEC COOLDOWN ******** "
echo " "
echo " "
./dashd stop
sleep 20
echo " "
echo " "
echo " ******** BACK UP PREVIOUS DASHD TO DASHOLD IN CASE NEW ONE DOESNT RUN PROPERLY, AND RUN NEW DASHD ******** "
echo " "
echo " "
mv dashd dashdold
mv darkcoin/src/dashd .
chmod +x ./dashd
./dashd
echo " "
echo " "
echo " ******** SLEEPING 5 MINUTES TO LET IT START UP ******** "
echo " "
echo " "
sleep 300
echo " "
echo " "
echo "******** SWAP OFF, TYPE PASSWORD ******** "
echo " "
echo " "
swapoff -a
echo " "
echo " "
./check
echo " "
echo " "
echo " "
echo " ******** MAKE SURE TO START MASTERNODE LOCALLY ******** "
Save the file with CNTRL-O --> return --> CNTRL-X
Make the file executable with:
chmod +x update
You can now update your masternode with one click!
./update
EDIT: 28-05-2015: I just found out i incorporated ./check command in the script which gives an error cuz its another script i got the check the stats
EDIT: 28-05-2015: the script starts with removing the file dashdold. This only exists when the scipt in run for the second time because the scipt renames dashd to dashdold, So when presented with an error dont freak out, it will continue.
You can compile the next version while the masternode is running and swap the file quickly.
Putty into the PI2
Check where you are and see the directory darkcoin. Then remove the darkcoin directory:
(Yes, although we are called DASH now the dir is still called Darkcoin)
ls
sudo rm -R darkcoin
NOTE Dont remove the hidden folder .dash
Download the newest source from github, enter the directory and compile the next version like you did before.(Yes, although we are called DASH now the dir is still called Darkcoin)
cd darkcoin
./autogen.sh
make
NOTE: Remember to leave putty open, or learn otherwise.
Check if the new darkcoind file is there and ready to be used:
cd src
ls
Now we stop the masternode and replace it with the new one. So head back two up to the main dir and stop and remove the file.
cd ../..
./dashd stop
(wait a minute)
rm dashd
Now we move the new one in the darkcoin/src dir to the current dir you are in atm. And make it executable, and run it!: (Yes, although we are called DASH now the dir is still called Darkcoin)
mv ~/darkcoin/src/dashd .
chmod +x ./dashd
./dashd
There you go! Its updated and started. Starting will take some time again. Check cpu with:
top
Start the masternode in your local wallet again (not always needed but i do it anyway for good measures)
Remember you can check if its running correct with:
./dashd getinfo
ENDNOTE: DONT OPEN PORT 22 IN YOUR ROUTER SO YOU CAN LOGIN WHEN AWAY FROM HOME. YOU BECOME MORE EASILY HACKABLE. JUST PORT 9999.
:rolleyes:If this tutorial has been helpful for you, dont be shy and donate some spare drk in my pocket. Thank you! :rolleyes:
:smile:GOODLUCK AND HAPPY MASTERNODING @ HOME!:smile:
Good one. I just picked up two PI2s, too. (lol)
I had the first one building the bitcoind and downloading the blockchain. It's only 16% done.
FWIW, I just did a make -j 4 on bitcoind and it worked without any problems. I didn't do any of the swap stuff you did above.
Was not sure what to do with the 2nd PI2. I was considering setting up a MN on testnet first, since I don't have much experience with a MN. Thanks for sharing your recipe. I may end up "testing" it. :)
I'd seriously consider "hardening" the distro.
Take a look at all of these logins that are enabled:
root:x:0:0:root:/root:/bin/bash
daemon:x:1:1:daemon:/usr/sbin:/bin/sh
bin:x:2:2:bin:/bin:/bin/sh
sys:x:3:3:sys:/dev:/bin/sh
games:x:5:60:games:/usr/games:/bin/sh
man:x:6:12:man:/var/cache/man:/bin/sh
lp:x:7:7:lp:/var/spool/lpd:/bin/sh
mail:x:8:8:mail:/var/mail:/bin/sh
news:x:9:9:news:/var/spool/news:/bin/sh
uucp:x:10:10:uucp:/var/spool/uucp:/bin/sh
proxy:x:13:13:proxy:/bin:/bin/sh
www-data:x:33:33:www-data:/var/www:/bin/sh
backup:x:34:34:backup:/var/backups:/bin/sh
list:x:38:38:Mailing List Manager:/var/list:/bin/sh
irc:x:39:39:ircd:/var/run/ircd:/bin/sh
gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/bin/sh
nobody:x:65534:65534:nobody:/nonexistent:/bin/sh
libuuid:x:100:101::/var/lib/libuuid:/bin/sh
pi:x:1000:1000:,,,:/home/pi:/bin/bash
eek. Pretty sure most of those should be set to /bin/false.
Don't forget to change the root pw. In fact, I'd create a new account and delete the pi account.
I'm lazy. Can you combine all of those pkgs onto one line? (like this)
This:
# ufw status
should be this:
# sudo ufw status
Tried building with -j4 without the swap steps... boom. "virtual memory exhausted: Cannot allocate memory" Just like you said.
Did the swap steps.
Change this:
to this:
and
mkswap /root/swap
to
Building now... with -j2
Now I wait... gotta run some errands anyways...
thx for the tips. I edited the tuts with your tips. I forgot sudo somwhere and did your apt-get install 'the whole bunch'. Mine failed so i entered them one by one, but that must have been a typo i guess.
To just disable users on the pi i dunno yet. I think i will test some stuff first in vmware before i disable them. I dont wanna break my Masternode just yet now its running so smooth.
EDIT: Split 8 in 8a and b. Rootpasword and user pi addressed.
# cat /etc/passwd | cut -d":" -f1
shows all users and:
# userdel -r login
removes them.
I succesfully removed user irc / games but dunno how far i can go.
darkred Can you test how far we can go on your second pi2?
# userdel -r login
removes them.
Sure. Not sure I want to remove pi user, yet. Let me make another pass.
Another thing... all of the commands that start with '#' look really good on the tutorial, but they're a bit painful to copy/paste because you have to select most of the line (without the # sign). The prompt is <user>@raspberrypi <dir>$ and not a # sign. Can you remove the leading character '#' to make it easier to copy/paste? I can make another pass from a fresh install.
My testnet never sync'd. You probably don't care as you're using this for a MN on the real darkcoin network.
It would get to some really close 99+% message:
2015-02-22 05:56:45 UpdateTip: new best=00000003014cd4211ddc7647057ae0b2a983c8415239aa36051c285a5223bbe1 height=9075 log2_work=40.557032 tx=10756 date=2015-02-22 05:56:14 progress=0.999983
Then several of these...
2015-02-22 05:56:45 ProcessBlock: ACCEPTED
2015-02-22 05:56:45 ProcessMessages(mnw, 145 bytes) : Exception 'CDataStream::read() : end of data' caught, normally caused by a message being shorter than its stated length
Then back to another 99+% message. On and on. Killed and restarted it multiple times. Let it churn for a long time.
Not sure what's up with that.
Any thoughts anyone?
Also, there was no "make check" step in your tutorial.
Which is probably good because they fail.
pi@raspberrypi ~/darkcoin $ make check
Making check in src
make[1]: Entering directory '/home/pi/darkcoin/src'
Making check in .
make[2]: Entering directory '/home/pi/darkcoin/src'
make[2]: Leaving directory '/home/pi/darkcoin/src'
Making check in test
make[2]: Entering directory '/home/pi/darkcoin/src/test'
make check-am
make[3]: Entering directory '/home/pi/darkcoin/src/test'
make check-TESTS
make[4]: Entering directory '/home/pi/darkcoin/src/test'
Running 115 test cases...
alert_tests.cpp(121): error in "AlertApplies": check alert.CheckSignature() failed
alert_tests.cpp(127): error in "AlertApplies": check alerts[0].AppliesTo(1, "") failed
alert_tests.cpp(128): error in "AlertApplies": check alerts[0].AppliesTo(999001, "") failed
alert_tests.cpp(129): error in "AlertApplies": check alerts[0].AppliesTo(1, "/Satoshi:11.11.11/") failed
alert_tests.cpp(131): error in "AlertApplies": check alerts[1].AppliesTo(1, "/Satoshi:0.1.0/") failed
alert_tests.cpp(132): error in "AlertApplies": check alerts[1].AppliesTo(999001, "/Satoshi:0.1.0/") failed
alert_tests.cpp(134): error in "AlertApplies": check alerts[2].AppliesTo(1, "/Satoshi:0.1.0/") failed
alert_tests.cpp(135): error in "AlertApplies": check alerts[2].AppliesTo(1, "/Satoshi:0.2.0/") failed
alert_tests.cpp(171): error in "AlertNotify": check r.size() == 4u failed [0 != 4]
unknown location(0): fatal error in "AlertNotify": memory access violation at address: 0x00000000: no mapping at fault address
alert_tests.cpp(172): last checkpoint
*** 17 failures detected in test suite "Bitcoin Test Suite"
FAIL: test_darkcoin
1 of 1 test failed
Please report to info@darkcoin.io
Makefile:1105: recipe for target 'check-TESTS' failed
make[4]: *** [check-TESTS] Error 1
make[4]: Leaving directory '/home/pi/darkcoin/src/test'
Makefile:1228: recipe for target 'check-am' failed
make[3]: *** [check-am] Error 2
make[3]: Leaving directory '/home/pi/darkcoin/src/test'
Makefile:1230: recipe for target 'check' failed
make[2]: *** [check] Error 2
make[2]: Leaving directory '/home/pi/darkcoin/src/test'
Makefile:859: recipe for target 'check-recursive' failed
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory '/home/pi/darkcoin/src'
Makefile:435: recipe for target 'check-recursive' failed
make: *** [check-recursive] Error 1
pi@raspberrypi ~/darkcoin $ git pull
Already up-to-date.
pi@raspberrypi ~/darkcoin $ git branch
* master
pi@raspberrypi ~/darkcoin $ git branch -a
* master
remotes/origin/HEAD -> origin/master
remotes/origin/consensus-voting-sysstem
remotes/origin/dsee-notes
remotes/origin/master
remotes/origin/master-mnpayments-debug
remotes/origin/master-v0.10
remotes/origin/masternode-blinding
remotes/origin/mnchanges
remotes/origin/revert-187-devel-0.9-strings
remotes/origin/revert-191-revert-187-devel-0.9-strings
remotes/origin/spork-reprocess
remotes/origin/v0.11.1.x
remotes/origin/v0.11.2.x
Not sure if I should switch to 11.2.x since I'm going to be on testnet for a bit...
BTW, my bitcoin one got to 26% sync'ed before it died. Looks like a memory leak...
2015-02-22 10:33:34 UpdateTip: new best=00000000000000001b895df68cb44e97ae64b2af45a2f660fb7fb4ad8d1d388b height=291143 log2_work=77.352432 tx=35081337 date=2014-03-18 09:08:06 progress=0.265558 cache=171169
2015-02-22 10:34:01
EXCEPTION: St9bad_alloc
std::bad_alloc
bitcoin in ProcessMessages()
This is what I did on the bitcoin one:
pi@raspberrypi ~ $ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
su pi -c '/usr/local/bin/bitcoind &'
exit 0
Perhaps we should do a similar thing on the darkcoind pi.
Also, I'm thinking of adding a croncheck to reboot if the process is not running.
How are you running raspberry pi in vmware?
Hmm... this is kinda close...
accts="daemon bin sys games man lp mail news uucp proxy www-data backup list irc list gnats nobody libuuid ntp"
pi@raspberrypi ~ $ for a in $accts; do echo sudo usermod -s /bin/false $a ; done
sudo usermod -s /bin/false daemon
sudo usermod -s /bin/false bin
sudo usermod -s /bin/false sys
sudo usermod -s /bin/false games
sudo usermod -s /bin/false man
sudo usermod -s /bin/false lp
sudo usermod -s /bin/false mail
sudo usermod -s /bin/false news
sudo usermod -s /bin/false uucp
sudo usermod -s /bin/false proxy
sudo usermod -s /bin/false www-data
sudo usermod -s /bin/false backup
sudo usermod -s /bin/false list
sudo usermod -s /bin/false irc
sudo usermod -s /bin/false gnats
sudo usermod -s /bin/false nobody
sudo usermod -s /bin/false libuuid
sudo usermod -s /bin/false ntp
To check...
pi@raspberrypi ~ $ cat /etc/passwd | grep sh
sshd:x:101:65534::/var/run/sshd:/usr/sbin/nologin
I cannot figure out why the mail account will not get disabled. I have also tried 'usermod -s /sbin/nologin' but that gets the same results.
Note: Ninjaedit... forgot to include the accts variable at the top.
Figured out my issue with the swap. You need to add /root/swap to the command. Here's how you can see if it has more swap. This is much better than using 'top'.
pi@raspberrypi ~ $ sudo swapon -s
Filename Type Size Used Priority
/var/swap file 102396 0 -1
pi@raspberrypi ~ $ sudo swapon /root/swap
/root/swap file 2097148 0 -2
pi@raspberrypi ~/darkcoin $ time make -j 4
<snip>
real 93m6.498s
user 119m14.620s
sys 7m6.260s
Without the -j (so it just uses one process to build all)
<snip>
real 93m22.457s
user 90m45.570s
sys 1m56.950s
Are you saying compiling with 1 core is quicker then 4?
And as for you bitcoin testing and testnet testing on the PI2. Remember im a linux freshman and just got the basics sorted. So i cant help u with that sorry.
Thanks for the user-disable testing. Does your PI2 still logs in as PI and ROOT? That the only one im using now atm. If so, i can safely put your commands in the tut!
It appears that compiling with 1 core is quicker than 4. I guess we can drop the -j option from the make. Still bummed about not being able to run 'make check'. But for now, that will have to do.
For grins, I re-did the test. I did a 'make clean' and 'sudo reboot', then:
Making all in src
<snip>
real 93m29.558s
user 90m53.890s
sys 1m57.160s
No worries about the other stuff.
You probably want to disable the root from being able to ssh. To do so, edit the ssh configuration file changing PermitRootLogin
pi@raspberrypi ~/darkcoin $ grep Root /etc/ssh/sshd_config
PermitRootLogin yes
# the setting of "PermitRootLogin without-password".
pi@raspberrypi ~/darkcoin $ sudo vi /etc/ssh/sshd_config
pi@raspberrypi ~/darkcoin $ sudo service ssh restart
[ ok ] Restarting OpenBSD Secure Shell server: sshd.
PermitRootLogin no
I like the change to colors. It looks purty. And, it makes it so much easier to copy/paste. Thanks for doing that.
You are still missing the swap command that I mentioned in a prior posting. See 'sudo swapon -s'. Ditch the 'top' command.
Oh. You'll want to setup some alerting for when the darkcoind is not running.
You'll want some sort of backup running.
You'll want some regular OS update/upgrade.
Also, check that your MN is paying something. Check for your MN on this web page: https://drk.mn/
lol... a little daunting... but not too hard one step at a time. :)
