Masternode on azure
acidburn
Active member
Does anyone run a masternode instance on Azure? If so, how much does it cost? I might have a way of getting one on the cheap.
I know you can fire up instances of vms in Linux.
First 5GB are free, after that you pay per GB
I use Azure and Windows 2012 servers, I just run the qt-wallet with masternode=1.
It's been about $15/mo on average with the bandwidth charges.
I will search cheaper options and more independent vps providers preferably outside the U.S. jurisdiction when I get the time and energy, I've just used Azure out of convenience.
So is there a way to setup a MN on Windows?
add: all works fine
