Masternode goes offline?
Lzeppelin
57
Hi my darkcoind kills itself for no reason after a week thus my masternode goes offline. I was just wondering is this happening to anyone else or is it just my VPS provider?
Propulsion
The buck stops here.
Feb 26, 2014
1,008
468
Could be memory management issue. Maybe try lowering max connections to the daemon. Yet to see a daemon shutdown for no reason though.
Are you using a small unknown provider?
Lzeppelin
57
I'm running with reprisehosting I have connections set at 256, if I go lower will there be any negative consequences?
Propulsion
Feb 26, 2014
1,008
468
Not that I'm aware. Possibly a slight delay with the IP to the network, but even then, I believe it waits 10 blocks for confirmation of MN creation.
