Linux DASHD - Check and Review - Script
Discussion in 'General Discussion' started by MangledBlue, Jun 2, 2015.
  1. MangledBlue
    MangledBlue Well-known Member
    Jun 28, 2014
    1,246
    678
    #1 MangledBlue, Jun 2, 2015
  2. MangledBlue
    Jun 28, 2014
    1,246
    678
    nano CODE: - updated from, time to time (zaman zaman)
    UPDATED: 06.07.2015
    MN code to check your MN
    You have to be using dash-cli along with dashd
    #!/bin/bash
    MNIP=`wget -qO- http://ipecho.net/plain ; echo | awk "{print \\$2}" | sed -e 's/addr://' | tr "\n" " "`;
    export GREP_OPTIONS=--color=always
    function wait_clear() {
    PROMPT="
    press enter or wait $1 seconds to continue "
    read -p "$PROMPT" -t $1 NOOP;
    clear;
    wait_clear 1;
    cat << EOF
    YOU MUST RUN
    DASH-CLI
    FOR THE DASH REVIEW
    WITH MASTERNODE
    TO PROCEED PROPERLY
    EOF
    wait_clear 5;
    cat << EOF
    *** START 'DASH' REVIEW - WITH MASTERNODE
    EOF
    wait_clear 5;
    cat << EOF
    *** CHECKING YOUR DASH MASTERNODE IP CONNECTION(S) ON PORT: 9999
    `netstat -an | grep 9999 | more`
    *** CHECKING YOUR DASH 'LISTENING' ABILITY
    *** LISTENING, ON PORT : 9999
    `netstat -an | grep LISTEN | grep 9999
    EOF
    wait_clear 10;
    cat << EOF
    ***GET-INFO FOR 'DASH'
    `./dash-cli getinfo`
    EOF
    wait_clear 8;
    cat << EOF
    ***YOUR DASH MASTERNODE 'IP' SHOULD = ENABLED
    `./dash-cli masternode list | grep $MNIP`
    EOF
    cat << EOF
    ***ZERO IS THE BEST SCORE FOR YOUR MASTERNODE
    `./dash-cli masternode list pose | grep $MNIP`
    EOF
    wait_clear 8;
    VOTES=`./dash-cli masternode list votes`
    cat << EOF
    ***ALL VOTING RESULTS FOR THE CURRENT DASH 'VOTE'
    YES = $(echo "$VOTES" | grep -c YEA)
    NO = $(echo "$VOTES" | grep -c NAY)
    ABSTAIN = $(echo "$VOTES" | grep -c ABSTAIN)
    YOUR VOTE = $(echo "$VOTES" | grep $MNIP)
    TOTAL MASTERNODE COUNT = $(./dash-cli masternode count)
    EOF
    wait_clear 10;
    cat << EOF
    HAVE A NICE DAY ........................................
    EOF
    wait_clear 5;
    cat << EOF
    PLEASE FEEL FREE TO DONATE TO THE FOLLOWING DASH ADDRESS
    XexrpL5LWdtzkDRspikBqR5Ue1Kt3zyduv
    *33% OF ALL DONATIONS WILL GO TO fuzzyduck
    *33% OF ALL DONATIONS WILL GO TO moocowmoo
    EOF
    exit;
    copy and paste into: nano [what-ever-you-want-to-name-it]
    to save: CTRL-x
    input: chmod +x ./[what-ever-you-named-it]
    to run: ./[name]
    enjoy :-D
    GOD I LOVE DASH :-D
    \o/ WOOT !!!!
    #2 MangledBlue, Jun 2, 2015
    • Like Like x 1
  3. fuzzyduck
    fuzzyduck Active Member
    Feb 19, 2015
    134
    93
    You're welcome! Al this credits for my simple script,, amazing!! :)
  4. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
    Sorry to say again here that "dashd [something]" will not available anymore in near future...:D
  5. buster
    buster Guest
    I asked three other spots might as well ask here also just to get it out there so people can see. Care to explain why the dashd command wont be available? I'm not sure I understand why.
    • Like Like x 1
  6. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    Migrating to 0.10 bitcoin will split "old" dashd to
    1) dashd - daemon
    2) dash-cli - lightweight cli program to run rpc commands
    and "dashd some_command" will not be available anymore
    Since the "masternode start" and etc. are rpc commands, all these communication with dash daemon will not allow running with "dashd" but still available for "dash-cli" command.
    So, "dashd" is available to start the daemon only. "dashd [something]" will not available like now. you should change to "dash-cli" , including "dash-cli stop" command to stop the daemon.
    • Like Like x 3
  7. MangledBlue
    Jun 28, 2014
    1,246
    678
    Hows about a little more info for us dash-cli noobs
    list of commands?
    Somebody want to construct a guide - for transitioning to dash-cli?
    ugh
    now I'll have to use 2 programs to run the MN?
    feels like a step backwards.....
  8. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    All the command run with dashd can be used by dash-cli with same parameter and format so I understand that just change dashd to dash-cli will works except the starting daemon , only "dashd" can do.
  9. TaoOfSatoshi
    TaoOfSatoshi Grizzled Member
    Jul 15, 2014
    2,714
    2,610
    So if I want to check my Masternodes it will be
    dash-cli masternode list | grep BLABLABLA?
  10. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    Yes, sir . You can try now, the dash-cli already included in your current installation. :)
    • Like Like x 1
  11. MangledBlue
    Jun 28, 2014
    1,246
    678
    So go to dashd : dashd masternode start
    then
    go to dash-cli and do everything else?
    if that's the case - no biggy
    I was starting to freak out that I had to re-learn a bunch of stuff
    thanx for the info :)
  12. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,637
    3,536
    Not exactly:
    1. start daemon (by hands or in cron):
    dashd
    2. issue some commands:
    dash-cli getinfo
    dash-cli masternode start
    3. stop daemon (if you need to):
    dash-cli stop
    EDIT: edited for readability
    • Like Like x 3
  13. MangledBlue
    Jun 28, 2014
    1,246
    678
    so ONLY dashd to start
    do everything else in dash-cli
    correct?
    So I'll have to move/copy dash-cli to .dash DIR
    ok - I think I got this figured out now
    between you and Lazy - I think I got this :-D
    please correct me if I'm wrong :-D
  14. MangledBlue
    Jun 28, 2014
    1,246
    678
    oh
    I will need to : chmod +x ./dash-cli
    right?
  15. UdjinM6
    3,637
    3,536
    You need to move dashd and dash-cli to the same path where you were usually moving dashd on update
    Yep, and for dashd too - you still need it to run daemon itself
    • Like Like x 1
  16. MangledBlue
    Jun 28, 2014
    1,246
    678
    I already have the chmod +x ./dashd
    but are you saying that I'll need to do the following once I copy and chmod the dash-cli?
    ./dashd
    ./dashd masternode start
    ./dash-cli
    ./dash-cli [cmd}
    ./dash-cli [cmd}
    like so?
  17. UdjinM6
    3,637
    3,536
    errr... no....
    I'm saying this https://dashtalk.org/threads/linux-dashd-check-and-review-script.5066/#post-55797
    and that you will need to update both dashd and dash-cli and make them executable
    • Like Like x 1
  18. UdjinM6
    3,637
    3,536
    The idea behind this is to have small standalone program that does nothing but rpc calls and has literally no complicated lib dependences. So you can compile it with just some c compiler and no qr, leveldb and all that kind of stuff.
    • Like Like x 4
  19. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    IMO, removing CLI functionality of RPC from daemon itself help reduce overhead during starting daemon and make smaller memory footprint , give better performance and faster startup... :)
    • Like Like x 2
  20. MangledBlue
    Jun 28, 2014
    1,246
    678
    so does that mean we want to move to a more "simple" form - like portable devices (smartphones) - and if so - did you see my proposal/theory for dynamic IP resolve on BCTalk
    If I knew how to code - I'd send you "something"
    read it and tell me I'm crazy - then find somebody to code it - lol
    https://bitcointalk.org/index.php?topic=421615.msg11529451#msg11529451
    There should/could be a way for the MN COLD side (dashd and/or dash-cli) to "ping" a request for the current IP every few seconds/minutes - Then the COLD side uses some kind of code to alter the COLD side .conf file IP - then send that same .conf file IP change to the HOT side thus keeping your MN in-sync with the IP while also letting the WHOLE MN system know that your IP change has occurred.
    LOL - I can see it now - A separate and NEW file would need to be created called: mnip.conf
    - that only contains your MN IP = write to mnip.conf new IP"
    etc
  21. MangledBlue
    Jun 28, 2014
    1,246
    678
    point is- even if you replace the IP with a malicious IP - your MN still gets paid - unless mismatched with hot and cold
    I just don't see dynamics IPs as an issue when you write to mnip.conf and send that "file" to the hot wallet if you have an encrypted confirmation signature - hand-shake - or whatever ​
  22. MangledBlue
    Jun 28, 2014
    1,246
    678
    UPDATED: 06.07.2014
    go to posts 1 and 2 of this thread
    thx
  23. Rux
    Rux Member
    Mar 9, 2014
    68
    32
    Can we send via instantx using rpc commands? :)
  24. MangledBlue
    Jun 28, 2014
    1,246
    678
    I've yet to see that CMD :p
    lol
  25. gujo82
    gujo82 New Member
    Jun 16, 2014
    29
    Got a small linux question regarding this switch.. Forgot to document everything when setting up my MNs, so abit in the dark here howto get dash-cli registered "globally" in the server, so it can be used from any directory?
    currently i start dashd from /usr/bin/ , and i can run all dashd commands from where-ever in the system..
    have tried placing dash-cli in usr/bin/ , altered chmod etc, but still only tells me it cant connect to the dash server.. both are running with the same account.
    edit: and now for some reason, it just works after a reboot... thought that magic was only for windows ;) :D
    #25 gujo82, Aug 17, 2015
  26. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    With our new release version of Dash core wallet, the command is "sendtoaddressix" as you may have seen it's action in evan's video clip.
  27. MangledBlue
    Jun 28, 2014
    1,246
    678
    Yep - I like it - good stuff
    Pay a bunch of people - REALLY REALLY FAST -
    • Like Like x 1
