Keepkey and Electrum?
wndsnb
Has anyone managed to get a Keepkey wallet working with Electrum-Dash?
When I try to create a wallet with my Keepkey, I get this error:
akhavr
789
396
I don't have a keepkey (looks like I have to buy one...)
Please, make sure that you have the complete installation, in particular whether the hid module is installed correctly. I guess you're under linux, right?
akhavr
789
396
Is this happening only with keepkey wallet, or with regular wallets too?
Dariusz Myśliwiec
11
I got this error just while using the Electrum-Dash.
EDIT: I'll try to elaborate on it and look for some fixes to it, but don't promise anything.
tungfa
8,902
6,733
did u try it with DMT App ? (no electrum but keepkey direct ) ?
Dariusz Myśliwiec
11
Didn't try this tool yet, since I thought it's related to MN operations. The problem I have is to retrieve the accounts to Electrum and do regular spending. If DMT have some module for KeepKey, I'll try to verify if it works fine and let you know, so the working code can be copied from DMT to Electrum.
tungfa
8,902
6,733
my bad
sorry thought we are talking MN here
don't they have their own wallet as trezor.wallet ?
Dariusz Myśliwiec
11
No worries :)
They do have their own web wallet, but the upgrades are slow (eg. for Dash it still has the higher fees for transactions). And the UI is pretty basic + no way to make multiple payments in one transaction.
Reactions: tungfa
Dariusz Myśliwiec
11
For now I can confirm that DMT works fine with my KeepKey on latest stable release.
Didn't have time to confirm more, but seems like the replacement of support library for KeepKey should fix this problem.
Dariusz Myśliwiec
11
Seems like I found the issue and I'm happy to provide a fix for it. It works for me at least. Because I cannot create new issue in the offficial GitHub for this project (https://github.com/dashpay/electrum-dash), I'm providing the fix here. I hope somebody can commit the solution to the repository and rebuild the sources:
In plugins/keepkey/keepkey.py there are missing lines at the end of the file, within KeepKeyPlugin class:
    def hid_transport(self, pair):
        from keepkeylib.transport_hid import HidTransport
        return HidTransport(pair)
    def bridge_transport(self, d):
        raise NotImplementedError('')
Please let me know if somebody will deal with it, or I can contribute somehow.
Edit: Seems like the code is already there, but the binaries for Windows don't have the fragment I've mentioned, so it just have to be recompiled from sources.
Reactions: UdjinM6 and tungfa
tungfa
8,902
6,733
@akhavr
i believe this one if for u
tx
Reactions: Dariusz Myśliwiec
akhavr
789
396
Thanks, this code will be included in our 2.9.3 release.
