ok you have btc equip I have ltc equip but it should work the same
in my case I mine on
www.litcoinpool.org it is a NO FEE or FREE Litecoin pool (not btc) that I mine my knc titans pow scrypt ltc
miners on..it also pays out 3% free bonus...so in my case with LTC I get 3% free over what I mine using this pool.
THUS what I did for the last 2 years was mine LTC and CONVERT IT Bitcoin using
www.shapeshift.io the fee ( I think
check yourself) was to convert LTC to BTC direct and instant (w/o use of an exchange as such) at 1.48% fee
thus I mined LTC to BTC and for the last 2 years have converted LTC to BTC in this manner to get 100 BTC in that
I did not want it to stay in LTC (a wise move in 2 years of 20/20 hindsight with BTC pump)
What I am considering now is doing the same thing above with DASH
So you would mine your Bitcoin S9 Sha256 pow coin Bitcoin Miner on a pool of your choice. Not sure if you can
find a btc pool such as the one I use above for ltc..but perhaps....
assuming you can find a FREE decent btc pool you mine BTC per usual..when the mood moves you...you
then go to
www.shapeshift.io and xfer your btc to dash say for the 1.48% fee (again check fees I think I am correct)
thus on a FREE BTC pool w/o a bonus you would eat a 1.48% fee for the trouble .....but if you pick the right coin
like me doing it from ltc to btc and/or you doing it from btc to dash..the bet is the coin you move too will out pace
the coin your particular miner can mine.
heh, my problem is I should have done this with dash last summer..however....in that my LTC to BTC conversion
has doubled my crypto in BTC by moving my LTC to BTC asap (or when I think the ratio is good) it has worked well
I'm just now considering maybe doing the same with my miners that mine LTC now and using
shapeshift.io to move
to dash instead...or at least diversify more ...it is easy...no sign up or anything on shapeshift it is just a plain
xfer of capital...you say what coin you have (say btc) to dash...then next page says your dash address
your btc address to refund in case of a problem....and how MANY (in small print) you are allowed to move at one
time (if you go over the amount they allow for a switch it will auto refund....this is just for the 1 time you can move
the max they say then repeat right after with a new transaction)
then another page comes up after that 2nd page...says the address to send your btc to them and also
it will list the dash address the btc will be xfered to...and it waits
you can even bail at this point ...just do a test run no money involved..then move like whatever the min amount
on the page of btc it says you can move as a test...
again simple 1st page coin to go from (btc) coin to go to (dash)
hit agree to terms box
return
2nd page....address it is going to (dash) address return or other btc address it can bounce back to if problems
3rd page.
tells you the amount you can send (min) and (maximum) in btc
the address you need to send funds to (btc) and the address dash those funds will convert into (dash)
that's it ...you can also flush direct from your pool ..depending on settings and you can use another address (btc)
then the one you move the btc from as your just in case it hangs return address..they just want a btc address
to return to if something goes wrong..only reason it is there can be any btc address you control does not have
to be the address you used in btc to move the coin to dash
anyway play with it ..move some dust small btc around to test..but in my case with scrypt equip paid off
and at litecoinpool at 103% ...and me getting 101.52% over mining LTC anyway in the xfer..it has worked
slick for me moving ltc to btc..should work just fine ...
again play with shapeshift look the pages over till you get how easy it is..move a small amount of btc
to something till comfortable with it...again in my case...has worked slick to move ltc to btc over 2 years
had one issue with them..my fault ...moved too much and did NOT fill in the return LTC address if problems
(duh) contacted them via email and they sent me back 1k usd to the address I sent the ltc from...don't do that
so just make sure you are not sending more then they will take at that transaction (you can do many in a row
if you have a lot to move over their max) and always fill in the return to your wallet address for the coin your
moving......it takes quite a bit to mess up like i did
anyway ..i may move some ltc to dash tonite .that will put me at like 0.88 dash...zowie (so missed the boat)
