How to mine on DashMiner pool with D3
Discussion in 'Mining' started by Czarekplpl, Oct 3, 2017.
  1. Czarekplpl
    Czarekplpl New Member
    Oct 3, 2017
    Hello. How to mine on DashMiner pool with Antminer D3?
  2. Andy75
    Andy75 New Member
    Jul 18, 2017
    13
    1. you log in to miner web console
    2. go to -> MINER CONFIGURATION tab
    3. put in pool address , worker , password under pool 1 , 2 , 3 RECOMMEND TO HAVE AT LEAST 1 BACKUP POOL
    4. click SAVE AND APPLY
  3. Czarekplpl
    Oct 3, 2017
    Problem is that pool do not need worker but public key:
    You can specify sgminer parameters from a command line or edit sgminer.conf. There are 3 important parameters to set:
    • your DASH or Bitcoin wallet address (-u parameter)
    • your email (-p parameter)
    • server (-o parameter)
    For example:
    sgminer.exe -o sf -u XpAy7r5RVdGLnnjWNKuB9EUDiJ5Tje9GZ8_test -p [email protected]
    Make sure you specified your wallet address correctly!
    Can I configure Antminer for this pool?
  4. Andy75
    Andy75 New Member
    Jul 18, 2017
    13
    1. which pool you try connect your miner to ?
    2. are you sure we talk about antminer D3 ? cause it uses cgminer (probably custom)
  5. Czarekplpl
    Oct 3, 2017
    Antminer D3 for sure. Pool is dashminer.com
  6. Andy75
    Andy75 New Member
    Jul 18, 2017
    13
    contact them for information , seems they use own miner software , which wont work with asic only with AMD gpu cards
  7. Czarekplpl
    Oct 3, 2017
    Thanks. I will.
  8. Waccery
    Waccery New Member
    Oct 17, 2017
    10
    I am not sure about it .
  9. cygnus81
    cygnus81 New Member
    Nov 22, 2017
    6
    sorry . the address should using BTC or DASH wallet address
