please tell me how to get the address from the code with this code:
import hashlib
p = 0xFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEBAAEDCE6AF48A03BBFD25E8CD0364141
#r = 0xd47ce4c025c35ec440bc81d99834a624875161a26bf56ef7fdc0f5d52f843ad1
#s1 = 0x44e1ff2dfd8102cf7a47c21d5c9fd5701610d04953c6836596b4fe9dd2f53e3e
#s2 = 0x9a5f1c75e461d7ceb1cf3cab9013eb2dc85b6d0da8c3c6e27e3a5a5b3faa5bab
z1 = 0xc0e2d0a89a348de88fda08211c70d1d7e52ccef2eb9459911bf977d587784c6e
z2 = 0x17b0f41c8c337ac1e18c98759e83a8cccbc368dd9d89e5f03cb633c265fd0ddc
# r1 and s1 are contained in this ECDSA signature encoded in DER (openssl default).
der_sig1 = "30440220d47ce4c025c35ec440bc81d99834a624875161a26bf56ef7fdc0f5d52f843ad1022044e1ff2dfd8102cf7a47c21d5c9fd5701610d04953c6836596b4fe9dd2f53e3e01"
# the same thing with the above line.
der_sig2 = "30440220d47ce4c025c35ec440bc81d99834a624875161a26bf56ef7fdc0f5d52f843ad102209a5f1c75e461d7ceb1cf3cab9013eb2dc85b6d0da8c3c6e27e3a5a5b3faa5bab01"
params = {'p'
,'sig1':der_sig1,'sig2':der_sig2,'z1':z1,'z2':z2}
def hexify (s, flip=False):
if flip:
return s[::-1].encode ('hex')
else:
return s.encode ('hex')
def unhexify (s, flip=False):
if flip:
return s.decode ('hex')[::-1]
else:
def inttohexstr(i):
tmpstr = hex(i)
hexstr = tmpstr.replace('0x','').replace('L','').zfill(64)
return hexstr
b58_digits = '123456789ABCDEFGHJKLMNPQRSTUVWXYZabcdefghijkmnopqrstuvwxyz'
def dhash(s):
return hashlib.sha256(hashlib.sha256(s).digest()).digest()
def rhash(s):
h1 = hashlib.new('ripemd160')
h1.update(hashlib.sha256(s).digest())
return h1.digest()
def base58_encode(n):
l = []
while n > 0:
n, r = divmod(n, 58)
l.insert(0,(b58_digits[r]))
return ''.join(l)
def base58_encode_padded(s):
res = base58_encode(int('0x' + s.encode('hex'), 16))
pad = 0
for c in s:
if c == chr(0):
pad += 1
else:
break
return b58_digits[0] * pad + res
def base58_check_encode(s, version=0):
vs = chr(version) + s
check = dhash(vs)[:4]
return base58_encode_padded(vs + check)
def get_der_field(i,binary):
if (ord(binary) == 02):
length = binary[i+1]
end = i + ord(length) + 2
string = binary[i+2:end]
return string
else:
return None
# Here we decode a DER encoded string separating r and s
def der_decode(hexstring):
binary = unhexify(hexstring)
full_length = ord(binary[1])
if ((full_length + 3) == len(binary)):
r = get_der_field(2,binary)
s = get_der_field(len(r)+4,binary)
return r,s
else:
return None
def show_results(privkeys):
print "Posible Candidates..."
for privkey in privkeys:
hexprivkey = inttohexstr(privkey)
print "intPrivkey = %d" % privkey
print "hexPrivkey = %s" % hexprivkey
print "bitcoin Privkey (WIF) = %s" % base58_check_encode(hexprivkey.decode('hex'),version=128)
print "bitcoin Privkey (WIF compressed) = %s" % base58_check_encode((hexprivkey + "01").decode('hex'),version=128)
import hashlib
params = {'p'
if flip:
else:
if flip:
else:
def inttohexstr(i):
tmpstr = hex(i)
return hexstr
def dhash(s):
def rhash(s):
return h1.digest()
l = []
while n > 0:
return ''.join(l)
pad = 0
for c in s:
if c == chr(0):
pad += 1
else:
break
return string
else:
return None
return r,s
else:
return None
