Help with my antminer D3
Ahmed2A
Hi,
I am on my way to have my antminer D3 in November. So I want to ask what is the best pool for this antminer ?
Another question, I attached a photo about miner configuration,
I see some pool has a long URL like in Zpool with address and password, what should I have to do with it ?
And is that worker same to my wallet ID ?
Thanks
Hi,
Thanks
Hi for some reason we have match less profit , with hashing rate around 15 g, is anyone knows what exactly going on with D3 ?
I am using p2pPool, because I like decentralization.
You can check
http://www.p2poolmining.us/p2poolnodes/
to find one next to your location
With p2p use the following information to get started:
Pool URL: stratum+tcp://(put here the pool-IP):7903
User ID: your dash wallet address
Password: use any password (ignored by pool)
I do not know Zpool, but at most other pools I visited you need to register first. Then you need to create a worker on their Homepage.
For suprnova.cc it works this way:
https://dash.suprnova.cc/index.php?page=gettingstarted
Check Zpool FAQ.
