Hello, Could someone help me?
Mikko Joshua
I sent bitcoin to this DashCore wallet but seems to be out of sync. What to do now? :/
you can NOT send btc to dash wallet ! they will NOT show up
as btc has their own wallet and system and blockchain
and so does Dash
and so does Dash
OOops, sorry I meant Dash coin. I uninstalled the application then reinstall and the wallet address changed. So that means my money is gone now. Right? Feelsbadman
- so u send dash to dash ?
- let wallet sync and coins will show
- if u erase the old wallet.dat and start new the old address is gone as not in your controll anymore
(always : install wallet 1st - let wallet sync - encrypt wallet -- then send / receive coins -- as posted in all guides !!)
Okay, then my balance is really lost. Ok, nvm. Thanks for the quick response.
Btw, the $ that I was receiving using the wallet was from the promotional #FirstDashWallet. Glad you guys made that but Im quite sad coz i didnt get to have that and give the half to my friend
Wallet.dat only. No encryption key as network is not established or stucked at out of sync. So yea, I uninstalled now the application for PC.
