Followed pi 3 MN tutorial, downloaded 0.12.0.59 not .58
Discussion in 'Masternode Questions and Help.' started by MasternodeX, Jan 2, 2017.
  1. MasternodeX
    MasternodeX New Member
    Jan 2, 2017
    Followed the MN tutorial (actually had to look at a few to get it working)
    Anyway just noticed in my getinfo in the putty terminal and noticed the version was different than my server/local wallet.
    Anyway the version is yellow on the masternode page, but everything else is green. What command do I use to get the right github version so i can recompile and make dashd work again with the version that everyone else is running (ie 0.12.0.58) because the command for the latest dash in github wasnt right.
    Do I just go here
    git clone github-DOT-com/dashpay/dash/tree/v0.12.0.58
    cd darkcoin
    ./autogen.sh
    ./configure --with-incompatible-bdb
    mv dashd ../..
    and do the thing to compile it and then run it?
    Took me hours today to get it working but almost there wooooo!!
  2. MasternodeX
    Jan 2, 2017
    did this
    cd .dashdownload
    wget [insert current Linux download link]
    tar xfvz [dash-0.10.17.23-linux.tar.gz] <<< replace this with the current file
    dashd stop
    sudo rm /usr/bin/dashd
    sudo rm /usr/bin/dash-cli
    cd [darkcoin-0.10.17.23-linux/bin/64] <<< navigate to the correct DIR
    sudo cp dashd /usr/bin
    sudo cp dash-cli /usr/bin
    sudo chmod 775 /usr/bin/dashd
    sudo chmod 775 /usr/bin/dash-cli
    cd
    dashd start
    or something like it, and just used the pi2 from the dash.org site, unzipped it and re-wrote over the files dashd and dash-cli.
