Error starting dashd: Error: Initialization sanity check failed.
Discussion in 'Daemon and QT Wallet Support' started by Lebubar, Sep 24, 2015.
  1. Lebubar
    Lebubar Active Member
    Mar 15, 2014
    252
    213
    I'm trying a new VPS for my next MN and got this error at starting dashd:
    [email protected]~$ ./dashd
    Error: Initialization sanity check failed. Dash Core is shutting down.
    Did someone have a clue? (lib missing or something?)
  2. stilldark
    stilldark New Member
    Feb 11, 2016
    7
    Also getting this error on Debian 6, 2.6.32 kernel (yes, I know it's old). Running on an OpenVZ VPS container. The code compiles but won't run. It must be something fairly low level, strace gives me:
    mmap(NULL, 8392704, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f0698b21000
    mprotect(0x7f0698b21000, 4096, PROT_NONE) = 0
    clone(child_stack=0x7f0699320fd0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f06993219d0, tls=0x7f0699321700, child_tidptr=0x7f06993219d0) = 25555
    umask(077) = 022
    rt_sigaction(SIGTERM, {0x438f5d, [], SA_RESTORER, 0x7f0699aadff0}, NULL, 8) = 0
    rt_sigaction(SIGINT, {0x438f5d, [], SA_RESTORER, 0x7f0699aadff0}, NULL, 8) = 0
    rt_sigaction(SIGHUP, {0x438f94, [], SA_RESTORER, 0x7f0699aadff0}, NULL, 8) = 0
    getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
    open("/proc/stat", O_RDONLY|O_CLOEXEC) = 3
    read(3, "cpu 228117 196315 19710 1126196"..., 8192) = 449
    close(3) = 0
    mlock(0x7fffc5220000, 4096) = 0
    munlock(0x7fffc5220000, 4096) = 0
    futex(0x7f0699ed0990, FUTEX_WAKE_PRIVATE, 2147483647) = 0
    fstat(1, {st_mode=S_IFREG|0644, st_size=16980, ...}) = 0
    mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f069c0cd000
    write(1, "Error: Initialization sanity che"..., 71Error: Initialization sanity check failed. Dash Core is shutting down.
    Any thoughts?
  3. AliMakavelli
    AliMakavelli New Member
    Friday
    i got this as well. any thoughts?
  4. AliMakavelli
    Friday
    i just tried on a computer with an updated OS and it seemed to work fine..;.then the computer power supply failed!!! Nothing to do with the app obviously...so my humble uneducated opinion is IT NEEDS TO RUN ON UPDATED OPERATING SYSTEMS.
Share This Page
