I mean, the money in circulation isn't really affected by the DASH held back. So why should they stabilize the price?
it is all psychologicalI mean, the money in circulation isn't really affected by the DASH held back. So why should they stabilize the price?
What do you think of the current model? 45% miners / 45% MN / 10% teamThe problem here is the logic that simply "existing" stabilizes prices. The MN system poses a risk in that mining centralization through ASIC production in a relatively small transaction volume environment can reduce returns to MNs as well as miners by creating too many MNs. The reward structure is that 45% of a block reward goes to miners, 45% goes to MNs. If transactions per MN fall too rapidly then decreasing returns could lead to a negative feedback loop where MNs liquidate their position to book profits and diversify into chains that offer better opportunities. This is a fundamental and proven risk of PoS. Instead of "stabilizing" what you find is that an artificial supply constraint causes prices to run up quickly and then at a certain price level the incentive to take profit becomes so high that stakeholders all try to beat each other to the exits, causing massive price crashes that cascade repeatedly until the coin is basically worthless. See for example NXT, the first PoS coin, and others that have demonstrated the inherent instability of PoS design and have sufficient chart history to show this instability in action. I wouldn't say this characteristic applies in exactly the same way to DASH since the hybrid structure and relatively small number of stakeholders seem to be more stable in practice but I'm not exactly clear whether this has more to do with loyalty, some other reason, or financial incentives.
The reason Ethereum is moving very slowly towards PoS is partly because they don't fully understand the game theory or the economics behind it. In many ways DASH is highly experimental and fueled by significant amounts of online propaganda, which is a reason to be skeptical of their governance and the potential for price manipulation. Ultimately, all that matters is that they increase their user levels at a reasonably high rate, which would lead to higher prices and stronger incentives for a stable MN network and miner network. If MN levels more or less track changes in transaction levels then I would say there's not much risk to the system. If MN levels increase at a higher rate than transaction levels then that might pose a risk since the price "pump" could create incentives for MNs to exit due to diminishing returns.
IMHO, MNOs program make things much more better and healthier for Dash itself. Why ?I mean, the money in circulation isn't really affected by the DASH held back. So why should they stabilize the price?
Good point, I think that is the main point. Having it all set up and running you are happy with your dividend and don't worry about trading or other things. Also there might be tax problems if you sell and rebuy all the time.it is all psychological
u can sell your MN collateral anytime obviously - but when u have a MN up and running u will not sell only because of a rise / fall in price (and go through the whole "hustle" of setting MN up after again)
if u have one up and running u will let it be and up and running
and that obviously stabilises the price![]()
This, I agree with 100%, no one will want to go through the whole process again and again just to move in and out of a masternodeit is all psychological
http://178.254.23.111/~pub/Dash/Dash_Info.htmlperfect.. where did you got your info? i will send and email asking the source of the data for that pic i showed..... just sharing info, best regards
