Hello,
thank you very much for the support in the last thread.
Following that dashninja.pl started to show it as active. This is great.
The problem is that I had tu turn off and on the Dash Core program in my computer and now over there is says:
STATUS: NEW_START_REQUIRED
On the other side Dashninja.pl says that the masternode is running fine and dashcentral.org says STATUS:OK.
LATE ADD: the ip address of the masternode is: 108.61.117.186
If I understand it correctly the moment in which I press START ALIAS the masternode counting will start again. And I will have lost the possibility to be paid for this first week when it was on. Right?
So do I really need to restart the masternode?
Many Thanks,
Pietro
Many Thanks,
Pietro
