DIY Deterministic Addresses (BIP32) & import private key
JW88
Hi All,
please help..!
Have followed the instructions to make DIY deterministic addresses
as given in the official documentation, however, now that I wish to send some Dash, I've put
walletpassphrase YOURWALLETPASSPHRASE 60
importprivkey XHoP-----------------------------------DnwgE2 0p/0/1 true
into the console and all i get back is
Error: Error parsing JSON:importprivkey
Does anyone know what the problem is...?
Thanks
Hi Chaeplin,
thanks for your reply, have tried the format suggested, but still get back:
I have no problem. If you have any special characters as label, use alpha + digit only.
use "help importprivkey" to check all command option.
importprivkey XKbp3ni47FEDNsyPY9js8EAbJYRsoZfEusbibvNjg2qWqeKZgZLL test true
19:29:42
19:29:50
importprivkey "XKbp3ni47FEDNsyPY9js8EAbJYRsoZfEusbibvNjg2qWqeKZgZLL" "sadasda" true
19:29:50
Thanks again for your help, its all working now, but I'm not sure exactly what made the difference....? As I tried same input before..... oh well, thanks Chaeplin
