dashd stuck in block 769066
Marcelo Rocha
I found a strange issue, my dashd is stuck at block 769066, and I cannot find the next blockchash for this block in explorer.
But looking for 769065, I found this info with "2" next blocks.
explorer.dash.org/block/00000000000000506169abc3424124edae815a53cc01b77bbd6adbecc1377206
Any ideas?
Thanks.
3,638
3,538
Check if it's reorged now. If not, use "reconsiderblock 00000000000000219eb0ff02c8ac196eeaceee1ce7453d228a1af77e129b607f" to get back on track.
Aslo pls update to 12.2.1 ASAP
Marian
12
I have very similar problem, since 11.11 my node gets stuck like 5 times/day. I need to restart node and after that it works. I still have 2.1.5 version, I can not upgrade now due to various reasons. Will it behave like this as long as I will have old version? If yes, why?
Marcelo Rocha
Thanks UdjinM6m,
This problem happened with version 12.2.1, started dashd with -reindex fixed the problem.
