dash-qt: Coin Selection window not sorting correctly by Amount
Discussion in 'Development Tech Discussion' started by jimbursch, Sep 7, 2017.
  1. jimbursch
    jimbursch Active Member
    Mar 5, 2017
    837
    499
    In Dash-QT when I open up the Coin Selection window (Send: Inputs: Coin Selection) and sort the inputs by Amount, it does not sort correctly. Is this a known issue?
    ping @UdjinM6
  2. AjM
    AjM Well-known Member
    Jun 23, 2014
    1,332
    570
    Works ok for me, win7x64.
  3. jimbursch
    Mar 5, 2017
    837
    499
    I'm using Ubuntu; here is a screen capture:
  4. doodlefax
    doodlefax New Member
    Jun 15, 2017
    36
    This is Dash Core version v0.12.1.5 (64-bit) download?
    Dogecoin has a similar issue, though in their case the wrong sort order is lexicographic and the comments suggest that locale setting may be the cause.
    https://github.com/dogecoin/dogecoin/issues/1289
    Sorting is handled by QT. In dash-qt, an extra column is added just for the purpose of sorting
    (containing the column text padded to the left to a fixed width so that lexicographic order is numerical order).
    The QT documentation is vague about sorting. This QT forum link gives some more useful information.
    https://forum.qt.io/topic/61239/how-does-qtreewidgetitem-sortchildren-sort/2
    (Bitcoin-qt wallet uses setData and UserRole on the items, as suggested in that link, rather than using an extra column.)
    (Sorting by the 'model' data itself may be a more correct approach, though our data is grouped by address.)
    This is probably a 'red-herring' - in your screenshot the (trailing) rows with PS rounds are sorted while the (leading) rows with PS rounds n/a are sorted if the group with the same 'Received with address' are represented by the first group item.
