Dash N Go - WiFi Portal Project Complete
Discussion in 'General Discussion' started by Solarminer, Aug 11, 2016.
  1. Solarminer
    Solarminer Well-known Member
    Apr 4, 2015
    762
    921
    163
    The Wifi-Portal Project was started with this proposal:
    https://www.dashwhale.org/p/Wifi-Portal
    And updated in this thread:
    https://www.dash.org/forum/threads/any-update-on-“wifi-portal“.8473/#post-89714
    This project is now considered complete. The original plan was to create a device that would act as a captive wifi portal. It ended up that this part was not a good solution. It also became impractical to create a mobile app that can automatically login to a secure wifi portal. Instead, we focused on created a mobile app that could download information from a web server.
    The start of this project we had the support of @fulltimegeek to help with android development. @tomasz.ludek helped immensely with the android portion and took the concept to completion. @TheDashGuy helped on website design and images. A special thanks to all is well deserved.
    The idea with this project was to create a system that you could pay for products by scanning with your phone and skipping the register. We were able to make a proof of concept for a few products. If this is to go into a commercial setting a store selector will need to be added to the app. Also this demo only had a few choices of soda to scan, a full solution will require an entire store product list to be on the server.
    The finished product is an android app you can download. It connects to a server that is hosting a product list and store info file. The app scans a product upc code then finds the cost and dash address in the product list file. It then converts to dash and adds to a cart. When you hit pay it pulls up your dash wallet to pay. When complete the receipt is shown.
    Below is an animated gif of the different steps.
    [​IMG]
    Feel free to download the app and view a few example files on dashngo.com. I setup Coke and Mountain Dew as product options, so you scan that soda on your desk and buy it for just 1 cent to try it out.
    • Like Like x 11
    • Winner Winner x 4
  2. Dunedoo
    Dunedoo Well-known Member
    Feb 25, 2015
    568
    600
    263
    Dash Address:
    XyoSz4xviVGfks1pLhaXw2Baqmhfw5k7MG
    Awesome
    One step closer for mass adoption
  3. alex-ru
    alex-ru Grizzled Member
    Jul 14, 2014
    2,368
    3,240
    Great!
    if somebody could produce a short video for http://www.dashngo.com how it is working - it'll be very useful (gif animation isn't very clear what is happening there...)
  4. polp
    polp New Member
    Jul 3, 2016
  5. raganius
    raganius cryptoPag.com
    Foundation Member Masternode Owner/Operator
    Jun 11, 2014
    719
    1,162
    263
    • Like Like x 2
  6. Miner237
    Miner237 Well-known Member
    May 28, 2014
    510
    223
    213
    How can I add this to buywithdash.com? will you and thedashguy being consulting for setting up stores for people?
    • Like Like x 1
  7. Solarminer
    Apr 4, 2015
    762
    921
    163
    This is really setup for point of sale at a physical store. If there is interest from a merchant, I can coordinate the changes needed for the app and the server side updates the store will need to make(basically adding 2 files on their website). I would imagine that merchants will want more security or to add new features like inventory management via the blockchain.
    • Like Like x 2
  8. Miner237
    May 28, 2014
    510
    223
    213
    I am trying to open physical store. With same products from web store. Trying to find a good space for sale still for physical store
