Dash Evolution System Architecture
TaoOfSatoshi
2,841
2,649
Dash Nation
www.dashnation.com
This diagram was posted by Andy Freer on the Dash Developer Discord. It shows how the flow of Evolution works, from the end user to the Dash network. What do you think? I for one can't wait to get this purring engine on mainnet.
Reactions: Nthelight
Geert
259
83
From what I understand, you won't be able to pay anyone via their Dash handle until you "friend" them. If this is true, I consider it a design flaw. Also, users' contact lists will be discoverable by examination of the blockchain, so that is another design flaw and IMHO a show-stopper. I would be pleasantly surprised if I'm wrong about these two points.
GrandMasterDash
3,137
1,227
Some might say, having unknown / shady individuals paying you and possibly tarnishing your reputation is a design flaw. Regardless, they are fully aware this feature is wanted. In the meantime, you can continue to pay people with dash in the normal way.
TaoOfSatoshi
2,841
2,649
Dash Nation
www.dashnation.com
Your first point is true, you have to establish a link between two parties before you can by via username. However, as @GrandMasterDash said, you are free to pay to address if you'd like before that happens. As for your second point, this is the first I'm hearing about this as addresses are not static, they are constantly changing while being linked to the identity. No two transactions to the same identity should use the same address, as far as I'm aware.
Geert
259
83
As for your second point, this is the first I'm hearing about this as addresses are not static...
I didn't say you will be able to determine who is paying whom. I said you will [AFAIK] be able to determine who is connected to whom.
