Dash Electrum Release - v0.2.4.1
eduffield
Mar 9, 2014
1,084
5,320
We are pleased to announce the first Dash Electrum release, 2.4.1. Electrum is fast a fast, stable and secure light wallet that generates your keys with a deterministic phrase. Simply write down the seed phase and put it in a safe place, you'll be able to restore your wallet from the seed at any point into the future.
Check it out here:
https://www.dashpay.io/downloads/
VERSION:
- 2.4.1 - beta1 - release candadate - notes: https://dashpay.atlassian.net/wiki/...y=DAS&title=Release+Candidate+1+Communication
tungfa
8,902
6,733
Woop Woop
Reactions: studioz
splawik21
Apr 8, 2014
1,927
1,287
Finally!! Gotta try it asap :)
Thnx
oaxaca
573
832
263
eduffield On the download page under linux, it says "Download setup.exe". Might want to rephrase that to something more nix-ish
tungfa
8,902
6,733
I don't understand what this is or does someone plz tell me ?
this is a light online wallet
you do not (as in QT) download the whole Blockchain anymore
easier , lighter , perfect for newcomers (and old dogs)
Reactions: Raico and meekee
nmarley
Jun 28, 2014
366
424
This is wonderful, my only concern — no PGP signature files from the developers. Shouldn't PGP sig files (detached clearsign) be standard for all Fintech software?
tungfa
8,902
6,733
Nice work.. Anyone tried on OSX 10.9x yet?
nope
will try this later tonight
Reg TREZOR :)smile:) can somebody please work on a guide !? now with electrum this should be so much easier to do !!
tx
edit:
please
please
pl.....
Reactions: splawik21
TaoOfSatoshi
2,819
2,622
Dash Nation
www.dashnation.com
Check it out here:
Excellent. I will try it out when I get home from work. DGBB dollars going to great use!
alex-ru
Jul 14, 2014
2,374
3,242
Cool!
But this page https://www.dashpay.io/downloads/ becomes a completely mess - too many links altogether to click - with too few explanations.
Can we organize this page to be more readable-clickable for new people? Maybe place Electrum in second column?
Can we use different colors/lines/fonts divisions to separate and explain different parts of this page? :sad:
Reactions: stan.distortion
tungfa
8,902
6,733
Cool!
But this page https://www.dashpay.io/downloads/ becomes a completely mess - too many links to click - with too few explanations.
Can we organize this page to be more readable-clickable for new people? Maybe place Electrum in second column? Use colors/lines/fonts divisions to separate and explain different parts of the page? :sad:
there is a redesign in motion, (the whole webpage)
as usual this will take a bit of time
but yes, i totally agree, there is a lot going on on that page
pille
273
302
123
Very good news!
I'm looking forward for a portable version. And the icon need to be replaced (Bitcoin logo inside?).
tungfa
8,902
6,733
Dash Electrum Update:
Release Candidate 1 Communication
https://dashpay.atlassian.net/wiki/...y=DAS&title=Release Candidate 1 Communication
We had a communication glitch with the Electrum version released yesterday ! It was actually a first Release Candidate (still under construction) and not a final version.
The development is still in progress and we need to identify issues in the current RC version. Feel free to help our testing team in the RC testing process and report your findings in the following thread: https://dashtalk.org/threads/dash-electrum-v0-2-4-1-support.6498/ or directly in the github repository: Https://github.com/mazaclub/electrum-dash/issues.
A new build is available for you to test, links below.
Some information you should be aware of during the testing:
  • This is not a debug-console release (console windows should not appear as app is run).
  • Auto-connecting is now enabled by default.
  • Fees that are above standard should display a dialog, which allows to cancel transaction. To display fees at all times, manual fee setting can be enabled (in settings dialog).
  • To address non-selectable text in QT dialog, here is a Settings option to show transactions before broadcasting. That will display the TxID and other relevant info in a selectable/copyable manner.
  • DRK servers cannot be renamed by other than their operators. Additions are, of course, simple.
  • Unverified transactions should show correctly after client has received.
  • Icons were not available for this build but will be present in the next build.
  • Readme files for installers will be present in the next build as well.
  • There is a known issue with pyinstaller creating binaries for OSX that may fail on machines that are configured similar to our build host, with macports installed.
    • OSX attempts to load 2 copies of QT dylibs, causing a segfault.
    • workaround is to temporarily make macports unavailable in OSX's dylib search path by moving it. This, in most cases, requires sudo permissions. (macports can be moved back into place immediately after Electrum-Dash is fully running - only startup is affected).
    • We are working this week to change the build system to use Homebrew instead of macports - This will have the added benefit of allowing our build system to execute on Travis-CI infrastructure, providing build automation.
Source Code
https://github.com/mazaclub/electrum-dash/
OSX Installer
https://s3-us-west-2.amazonaws.com/downloads.maza.club/Electrum-DASH-Installer_2.4.1_beta1.pkg
Linux Command Line Installer
https://s3-us-west-2.amazonaws.com/...m-DASH-2.4.1_beta1_Linux_x86_64-Installer.bin (requires sudo for system install, without for user directory install - chmod +xand run. Self extracting tarball/installer script, cat to view script.
Windows Installer
https://s3-us-west-2.amazonaws.com/downloads.maza.club/Electrum-DASH-2.4.1_beta1-Windows-setup.exe
kot
tungfa
8,902
6,733
Reactions: bhkien
B
buster
Guest
Is this electrum wallet functioning? Can I send/receive dash.
I've installed it but skeptical to use funds with. Is development still ongoing? Is budget still paying for dev?
Reactions: studioz
tungfa
8,902
6,733
this version is working for me (on Mac)
but i know there should be a new (even final) release coming out soon
kot knows more on this
tungfa
8,902
6,733
kot any feedback on the above ?
fible1
710
722
163
kot do you think that electrum support for masternodes is in the cards?
Pablo.
Reactions: buster
