Darkcoin > Dash
Discussion in 'Daemon and QT Wallet Support' started by utlord, Oct 13, 2017.
  1. utlord
    utlord New Member
    Oct 13, 2017
    Hi, i am trying to use my old Darkcoin wallet with Dash QT. Here is what it looks like.
    I do not know what are those transactions, i have not made them. Anyway my wallet shows 0 dash after full sync.
    I have tried.
    1. Upgrade wallet format
    2. Recover transactions 1 and 2
    3. Rescan blockchain
    Still 0 DASH
    If i run same wallet with old darkcoin QT it shows this, see uploaded image and of course it can not sync.
  2. Tallyho
    Tallyho Member
    Mar 15, 2015
    124
    68
    78
    Hi @utlord! First make sure your Darkcoin wallet.dat is backed up, preferably with multiple copies (Appdata > Roaming > Darkcoin assuming you're in Windows), then make sure you are running the latest Dash QT wallet. It should be v.0.12.1.5.
    Now, with the wallet shut down, locate Appdata > Roaming > DashCore and rename the wallet.dat that's in there to something else (you can delete it later). Copy over to that same folder the wallet.dat from your Darkcoin wallet. Start up the 0.12.1.5 wallet and let it sync.
    • Like Like x 3
  3. utlord
    utlord New Member
    Oct 13, 2017
    Done that, still no DASH.
  4. Tallyho
    Tallyho Member
    Mar 15, 2015
    124
    68
    78
    So what is happening? Is the 0.12.1.5 properly synced? Do you see any transactions in that wallet?
    Something puzzles me about your screenshots above. You said you don't recognise those transactions, and the dates show 2013!! Darkcoin/Xcoin genesis block wasn't until 19th January 2014, which makes every one of those transactions detailed in your screenshot impossible. (I'm happy to be corrected!) I have also plugged that address into the block explorer and it isn't recognised. Someone more technical may have a better suggestion, but all this suggests to me that your wallet.dat file is corrupted. Do you have another copy of the file that you can try?
    • Like Like x 2
  5. Obusco
    Obusco Member
    Sep 23, 2016
    41
    53
  6. alex9
    alex9 Member
    Feb 4, 2017
    57
    7
    • Useful Useful x 1
