CPU mining with Ubuntu (linux) and darkcoin cpuminer 1.3-avx-aes
TanteStefana
2,876
1,866
Open a terminal then cut and paste each line one at a time. I use this for my free Amazon EC2 account. I also have both my GPU and CPU mining together and it seems to work well for me :)
sudo apt-get update
sudo apt-get install -y build-essential m4 libssl-dev libdb++-dev libboost-all-dev libminiupnpc-dev git automake libcurl4-openssl-dev
git clone
cd darkcoin-cpuminer-1.3-avx-aes
chmod +x autogen.sh
./autogen.sh
./configure CFLAGS="-O3 -march=native"
sudo make
Now start it with:
sudo ./minerd -a X11 -o poolserver -u TanteStefana.Miner2 -p Pass -B
Just replace the blue with your pool and login info If you're using an Amazon ec2, and it got disconnected, when you reconnect, you just have to change directories to the mining directory with this:
then proceed to enter the start line above.
Reactions: S0AndS0
Lzeppelin
57
sudo apt-get update
sudo git clone
https://github.com/elmad/darkcoin-cpuminer-1.3-avx-aes
sudo chmod +x autogen.sh
sudo ./autogen.sh
sudo ./configure CFLAGS="-O3 -march=native"
sudo make
Now start it with:
sudo ./minerd -a X11 -o stratum+tcp://drk.lotterymining.com:4444 -u TanteStefana.Miner2 -p Pass
BUT WHAT ABOUT -funroll-loops?!!!!!!!!
n00b_miner
17
You can actually do a live disconnect using a couple of programs: nohup and screen.
nohup:
$ nohup command --and --flags 1> logfilename.log 2> logfilename.err &
This will disconnect the command from the current tty and it'll output everything on stdout to logfilename.log, and all stderr to logfilename.err. The important bit to send it into the background is the & at the end.
screen:
$ screen -d -m -S GIVE_THIS_SESSION_A_NAME command --and --flags
This is now my preferred way of doing this. It basically allows you to emulate as many virtual terminals as you like through one SSH session. When you run this command it should drop straight back to the terminal. Use
screen -r
to retrieve a started screen session. I run all my miners like this, and put the screen command in a bash script, so I can easily link them in an OS startup script.
Hope that's of use to someone :)
badseed
Tantestefana:
Installed fine, but when trying to run it says:
sudo: ./minerd: command not found
SuperTrooper
I have the same issue (Linux Mint Petra).
Below the verbose when I ran the sudo configure and the sudo make.
At the very end there are 2 errors while leaving the folder /home/SuperTrooper/darkcoin-cpuminer-1.3-avx-aes.
make[2]: *** [minerd-hash.o] Erreur 1
make[2]: quittant le répertoire « /home/SuperTrooper/darkcoin-cpuminer-1.3-avx-aes »
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire « /home/SuperTrooper/darkcoin-cpuminer-1.3-avx-aes »
make: *** [all] Erreur 2
[email protected] ~/darkcoin-cpuminer-1.3-avx-aes $
Darkuopm
50
17
I successfully got the miner working however when I close my ssh connection it stops mining. Do I have to keep my ssh connection active on my local pc? Thanks
*EDIT Weirdgod answered my question. I had to put -B in the start command to run in background in case any other linux noobs are reading this or having the same issue.
Reactions: MrMime
elmad
13
5
sudo apt-get update
git clone
chmod +x autogen.sh
./autogen.sh
sudo make
Now start it with:
You dont need to use sudo. Just work on a folder in your home folder and dont need superuser permissions. I edited your guide in the quote :) .
P.S. I had to remove the link because I have no permissions to post.
TanteStefana
2,876
1,866
Oh gosh, I'm sorry I haven't been around to check on this! Yah, I used screen to keep it live after I learned how, LOL. Didn't know about -B option for having it run in the background, that seems simplest. I added that, hopefully correctly. This is pretty old, not too many people will CPU mine anymore, but what the heck? eh?
Thank you elmad, I updated the instructions.
SuperTrooper, I'm sorry I can't read the errors, but I hope you figured it out and got it working!
Reactions: elmad
