Corrupt Masternode Walet after RC3 soft fork
blackempress
44
5
So I attempted to setup a darkcoind on a remote server. I created a wallet made an address and sent the money. Then suddenly the darkcoind crashed, and now I cannot open it up because it says wallet is corrupt and it was unable to salvage. I tried to move the wallet file to another computer and I get the same error.
Anyone have any idea how I can recover my massive losses?
I looked at the wallet file in a text editor and it just says NULL NULL NULL.... I'm beyond livid right now.
This is the address I sent it to but no longer have control because of the corrupted wallet.
blackempress
44
5
How does a wallet corrupt that easily? What is wrong with this new client? I never had any issues with bitcoin.
blackempress
44
5
Read my above post, I downloaded the new darkcoind, created an address sent money to it. Then the program crashed and my wallet is corrupt. Its nothing but 0's and I had just sent 1000 DRK to the address. Meaning i must lost 9700 dollars.
blackempress
44
5
I moved the wallet file and it says its corrupted and unsalavage. I just get beyond fucked over by darkcoin just now.
BrainShutdown
149
71
188
You do have a wallet.dat backup right?
blackempress
44
5
Please consider a hard fork. I went to start a masternode and sent 1000 a new wallet I setup on a VPS and then it suddently crashed and now says the wallet is corrupt. I checked the wallet in hex editor and it is all 0's.
Xcp5aAE56XpB19DkUjTvyptvGKGrZPv4cs
DarkCoin version v0.10.11.4-beta (2014-06-25 16:45:27 -0700)
Using OpenSSL version OpenSSL 1.0.1 14 Mar 2012
Default data directory /home/user/.darkcoin
Using data directory /home/user/.darkcoin
[email protected]:~$ Using at most 256 connections (1024 file descriptors available)
DarkCoin server starting
Using 8 threads for script verification
init message: Verifying wallet...
dbenv.open LogDir=/home/user/.darkcoin/database ErrorFile=/home/user/.darkcoin/db.log
Failed to rename wallet.dat to wallet.1403783993.bak
Error: wallet.dat corrupt, salvage failed
Shutdown : In progress...
StopNode()
Flushed 0 addresses to peers.dat 48ms
Shutdown : done
My backup I made right before I sent the money is fucked too, the wallet file made by the new darkcoind appears to be corrupted from the start.
blackempress
44
5
I have been using bitcoin since 2009, I have used several other alt-currencies. I never had an issue where the daemon crashed and my wallet file was completely corrupted. Then went and looked at my backups and they were just a wall of 0's in a hex editor.
blackempress
44
5
In fact I loaded another wallet with that darkcoind and now it has been corrupted by it as well. The new darkcoind posted in this thread has serious issues.
fandarig
17
blackempress. Doesnt really make sense to me you are since 2009 in bitcoin. How you dont have backups on a usb stick? Why are your backups corrupted as well, impossible? If its true im sorry for you.
blackempress
44
5
The TX ID that fucked me over beyond belief is here: 36aa400f5ca01352b8da5bdf7d032c87764f21c6b3c2f8a56ee2e087ce7755de-000
I tried making other wallets with the closed source masternode darkcoind and they are having the same issues.
yidakee
1,812
1,168
Mate, I feel for you, but there are 315 MN up and running fine. Its not the darkcoind. It was your download. Delete it and re-download it. Might not even be the wallet.dat
I'm on crypto's since Feb'14, and I send crumbles, encrypt, back-up, test, send crumbles out, backup, test... and then I send serious funds.
Also, might want to copy the wallet to another OS with "good" QT going, and try there.
blackempress
44
5
I would never back up on USB because flash is an approximation of your data first of all. Second it was a VPS so I couldn't use a USB.
Third after making the new wallet using the new closed sourced darkcoind I made a backup, I scp'd it to several servers and encrypted it. I then sent money to the address. After sending money I went back on the server and checked the darkcoind and it had crashed. So I reloaded it and it said the wallet file was corrupt. I opened a hex editor on one of the files I scp'd and it was a wall of 0's. To me it appears the new darkcoind is broken and is generating bad wallet files.
blackempress
44
5
I understand that its not broken for all cases, if it was it would have never been pushed live. But to pretend because it works in most cases means it doesn't fail in some cases is absurd.
yidakee
1,812
1,168
Look, dont want to get into a discussion here. Sincerely trying to help. I've been with darkcoin testnet since 2 months now, and I started as a linux virgin. Dozens of versions, and you're the first to report this issue. Not that its not real, but calm down dude. I know what you're going through, I almost shat myself during the last hard-fork sending 1k out.
Get a windows or mac, fire up the stable version of the QT, delete the wallet.dat generated, copy your "corrupt" wallet over to it, and see what happens!
Wasnt there a --rebuild option for wallets in the original bitcoind? IIRC... maybe darkcoind inherited it.
blackempress
44
5
I alread
I appreciate the advice, but unfortunately I already tried that. I scped the wallet.dat to my mac openeed it up in the newest QT and get the same error. Wallet corrupt could not salvage, which makes sence considering the wallet file in a hex editor shows just 0's.
This is worse than a hard fork issue, I cannot just rebuild the blockchain. The wallet I sent 1000 DRK to is now a blackhole because I have no access to the private keys.
yidakee
1,812
1,168
Just zero's ? It could have been your hard-drive with bad sectors while writing to it.
Wallet options:
-disablewallet Do not load the wallet and disable wallet RPC calls
-paytxfee=<amt> Fee per kB to add to transactions you send
-rescan Rescan the block chain for missing wallet transactions
-zapwallettxes Clear list of wallet transactions (diagnostic tool; implies -rescan)
-salvagewallet Attempt to recover private keys from a corrupt wallet.dat
-upgradewallet Upgrade wallet to latest format
-wallet=<file> Specify wallet file (within data directory)
-walletnotify=<cmd> Execute command when a wallet transaction changes (%s in cmd is replaced by TxID)
-spendzeroconfchange Spend unconfirmed change when sending transactions (default: 1)
Try -salvagewallet
blackempress
44
5
Try -salvagewallet
The server I did it on is a dedicated server with RAID I rented. Unfortunately I have also tried the salvagewallet flag :(
I had rented it just for setting up a masternode on. Was going to create multiple VPS for the other master nodes.
Don't mean to sound frantic but I just lost 9700 dollars and its very alarming.
JGCMiner
364
217
You are the only one with this issue. Nobody else has reported anything. Rather than blame DRK and call it broken go back and try to figure out where YOU differed from others and fix the problem.
It is very hard to imagine that the coin is broken as you imply.
blackempress
44
5
JGCMiner, I didn't do anything special. I used the newest closed source masternode darkcoind from this thread to create a wallet on a ubuntu machine and it failed to work.
You can pretend there are no issues because no one yet has reported them but me but that would be a major failure in logic.
thelonecrouton
1,135
813
JGCMiner
364
217
Not really, I consider it a bigger fail in logic to consider the 1 exception to the rule rather than consider the other hundreds of clients. Given the fact of the percentages, it is much much more likely that some sort of download or hardware problem on your end that corrupted the wallet than an issue with the source.
I hope you get your coins back. You should have brought this discussion up in the support sub-forum. You would likely find more help there.
Reactions: Populandum
yidakee
1,812
1,168
That is the second or third time you say "closed source" which makes me extremely suspicious.
Ok then. If darkcoind is corrupt, how did you manage to create an address to send it to?
Your server crapped out on you. Corrupted the file. Not darkcoind. Sorry dude. Probably a spike? If on RAID, data recovery?
You keep suggesting its darkcoind, but that makes no sense at all.
Please open a new thread to specifically address an attempt to recover your data.
blackempress
44
5
Suspicious about what? The masternode client is closed source, you don't like me stating facts? I normally compile all my cyrptocurrency clients from source.
My server never crapped out, the darkcoind client crashed and the server was fine. What else would it be if it wasn't darkcoind? It is the software I used to make the wallet, it is the software that crashed and can no longer open the file it generated.
You seem to be so blinded by the need to protect your investment we can seem to talk about any issues that arise.
stilgars
11
10
Please people don't antagonise him at the moment, as the RC3 software is bleeding new and just released - nobody could know for sure what happened. However, I am afraid that if your file is full of junk, nothing could be done to salvage it except extensive recovery procedures by specialist :-/
One must say however that your backup procedures were unfortunately insufficient for such catastrophic event
JGCMiner
364
217
This is what happens when you make hysterical posts in the wrong thread claiming that the client that everybody is using is broken -- not to mention you have provided almost no proof that any of this happened and your conclusion of "it is darkcoind" ignores many other more likely possibilities.
blackempress
44
5
Well I did provide proof, and if you actually cared to know more instead of trying to shut me down you could have asked for more and I would have happily provided it.
blackempress
44
5
This is the kind of response I expected, but maybe its because I develop software and didn't expect everyone here to just be investors but actually developers.
From what I can tell is my file is full of junk as well, especially after comparing it to my mac wallet.dat file. I may have already created too many new files on the linux machine in an attempt to salvage it to get it back.
I ran ./darkcoind getnewaddress masternode
Is there any chance this outputs the private key in any log when this is done?
