P2Pool Can't start my Dash pool
gizmoboss
Hi guys!
Installed OS: Ubuntu 17.10 server
Packages installed: python-zope.interface python-twisted python-twisted-web python-dev
gcc g++
Then i run: python run_p2pool.py i have an error like this
2017-12-18 11:57:57.688618 Testing dashd RPC connection to 'h**p://127.0.0.1:9998/' with username 'gizmo'...
Error while checking dash connection:
Failure: twisted.internet.error.ConnectionRefusedError: Connection was refused by other side: 111: Connection refused.
Please help me with my first setup what p2pool-dash
chaeplin
749
356
First try to change rpcpassword.
If your rpcpassword has special chrater(s), remove it and restart dashd, then test p2pool.
and dash.conf should have at least following config.
rpcuser=dashrpc#change
rpcpassword=veryvey-long-complicatedpassword=#change
rpcallowip=127.0.0.1
rpcbind=127.0.0.1
server=1
daemon=1
gizmoboss
rpcbind=127.0.0.1
server=1
daemon=1
Thanks
But now i have a another error:
Error getting work from dashd:
  File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 651, in _runCallbacks
    current.result = callback(current.result, *args, **kw)
  File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1355, in gotResult
    _inlineCallbacks(r, g, deferred)
  File "/usr/lib/python2.7/dist-packages/twisted/internet/defer.py", line 1297, in _inlineCallbacks
    result = result.throwExceptionIntoGenerator(g)
  File "/usr/lib/python2.7/dist-packages/twisted/python/failure.py", line 389, in throwExceptionIntoGenerator
    return g.throw(self.type, self.value, self.tb)
--- <exception caught here> ---
  File "/home/gizmo/git/p2pool-dash/p2pool/util/deferral.py", line 41, in f
    result = yield func(*args, **kwargs)
  File "/home/gizmo/git/p2pool-dash/p2pool/dash/helper.py", line 30, in getwork
    work = yield go()
  File "/home/gizmo/git/p2pool-dash/p2pool/util/jsonrpc.py", line 141, in _http_do
    raise Error_for_code(resp['error']['code'])(resp['error']['message'], resp['error'].get('data', None))
p2pool.util.jsonrpc.NarrowError: -10 Dash Core is downloading blocks...
splawik21
Yeah, it's me....
Apr 8, 2014
1,966
1,327
AFAIK it is already running @Nate M
104.207.141.32:7903/static/
