Building Dash locally using Visual Studio
james101
I've been trying to build dash locally for hours now but I'm stuck.
I cloned the repo, then created a new project from existing code in visual studio (using the src folder). When i go to build the project I get the following errors:
Anyone have any idea?
1>------ Build started: Project: TestCoin2, Configuration: Debug Win32 ------
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppBuild.targets(937,5): warning MSB8027: Two or more files with the name of governance.cpp will produce outputs to the same location. This can lead to an incorrect build result.  The files involved are governance.cpp, rpc\governance.cpp.
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppBuild.targets(937,5): warning MSB8027: Two or more files with the name of masternode.cpp will produce outputs to the same location. This can lead to an incorrect build result.  The files involved are masternode.cpp, rpc\masternode.cpp.
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppBuild.targets(937,5): warning MSB8027: Two or more files with the name of net.cpp will produce outputs to the same location. This can lead to an incorrect build result.  The files involved are net.cpp, rpc\net.cpp.
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppBuild.targets(937,5): warning MSB8027: Two or more files with the name of protocol.cpp will produce outputs to the same location. This can lead to an incorrect build result.  The files involved are protocol.cpp, rpc\protocol.cpp.
1>zmqpublishnotifier.cpp
1>zmq\zmqpublishnotifier.cpp(5): fatal error C1083: Cannot open include file: 'chainparams.h': No such file or directory
1>zmqnotificationinterface.cpp
1>c:\users\james\desktop\dash\src\zmq\zmqnotificationinterface.h(8): fatal error C1083: Cannot open include file: 'validationinterface.h': No such file or directory
1>zmqabstractnotifier.cpp
1>c:\users\james\desktop\dash\src\zmq\zmqconfig.h(19): fatal error C1083: Cannot open include file: 'primitives/block.h': No such file or directory
1>wallet_ismine.cpp
1>c:\users\james\desktop\dash\src\wallet\wallet_ismine.h(9): fatal error C1083: Cannot open include file: 'script/standard.h': No such file or directory
1>walletdb.cpp
1>wallet\walletdb.cpp(7): fatal error C1083: Cannot open include file: 'wallet/walletdb.h': No such file or directory
1>wallet.cpp
1>wallet\wallet.cpp(7): fatal error C1083: Cannot open include file: 'wallet/wallet.h': No such file or directory
1>wallet_tests.cpp
1>wallet\test\wallet_tests.cpp(5): fatal error C1083: Cannot open include file: 'wallet/wallet.h': No such file or directory
1>rpcwallet.cpp
1>wallet\rpcwallet.cpp(7): fatal error C1083: Cannot open include file: 'amount.h': No such file or directory
1>rpcdump.cpp
1>wallet\rpcdump.cpp(6): fatal error C1083: Cannot open include file: 'base58.h': No such file or directory
1>db.cpp
1>c:\users\james\desktop\dash\src\wallet\db.h(9): fatal error C1083: Cannot open include file: 'clientversion.h': No such file or directory
1>crypter.cpp
1>c:\users\james\desktop\dash\src\wallet\crypter.h(8): fatal error C1083: Cannot open include file: 'keystore.h': No such file or directory
1>versionbits.cpp
1>c:\users\james\desktop\dash\src\script/script.h(311): warning C4244: 'return': conversion from 'const int64_t' to 'int', possible loss of data
1>c:\users\james\desktop\dash\src\script/script.h(383): warning C4244: 'argument': conversion from 'int64_t' to 'const unsigned char', possible loss of data
1>c:\users\james\desktop\dash\src\script/script.h(453): warning C4267: 'argument': conversion from 'size_t' to 'uint16_t', possible loss of data
1>c:\users\james\desktop\dash\src\chain.h(312): warning C4018: '>=': signed/unsigned mismatch
1>c:\users\james\desktop\dash\src\chain.h(322): warning C4018: '<': signed/unsigned mismatch
1>versionbits.cpp(123): warning C4244: 'return': conversion from 'int64_t' to 'int', possible loss of data
1>versionbits.cpp(124): warning C4244: 'return': conversion from 'int64_t' to 'int', possible loss of data
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.12.25827\include\xutility(3126): warning C4996: 'std::equal::_Unchecked_iterators::_Deprecate': Call to 'std::equal' with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.12.25827\include\xutility(3126): note: see declaration of 'std::equal::_Unchecked_iterators::_Deprecate'
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.12.25827\include\xutility(3167): note: see reference to function template instantiation 'bool std::equal<_InIt1,_InIt2,std::equal_to<void>>(_InIt1,_InIt1,_InIt2,_Pr)' being compiled
1>        with
1>        [
1>            _InIt1=prevector<28,unsigned char,uint32_t,int32_t>::const_iterator,
1>            _InIt2=prevector<28,unsigned char,uint32_t,int32_t>::iterator,
1>            _Pr=std::equal_to<void>
1>        ]
1>c:\users\james\desktop\dash\src\script/script.h(582): note: see reference to function template instantiation 'bool std::equal<prevector<28,unsigned char,uint32_t,int32_t>::const_iterator,prevector<28,unsigned char,uint32_t,int32_t>::iterator>(_InIt1,_InIt1,_InIt2)' being compiled
1>        with
1>        [
1>        ]
1>c:\users\james\desktop\dash\src\serialize.h(267): warning C4244: 'argument': conversion from 'uint64_t' to 'uint8_t', possible loss of data
1>c:\users\james\desktop\dash\src\serialize.h(667): note: see reference to function template instantiation 'void WriteCompactSize<Stream>(Stream &,uint64_t)' being compiled
1>        with
1>        [
1>            Stream=CSizeComputer
1>        ]
1>c:\users\james\desktop\dash\src\serialize.h(683): note: see reference to function template instantiation 'void Serialize_impl<Stream,28,unsigned char>(Stream &,const prevector<28,unsigned char,uint32_t,int32_t> &,int,int,const unsigned char &)' being compiled
1>        with
1>        [
1>        ]
1>c:\users\james\desktop\dash\src\serialize.h(964): note: see reference to function template instantiation 'void Serialize<Stream,28,unsigned char>(Stream &,const prevector<28,unsigned char,uint32_t,int32_t> &,int,int)' being compiled
1>        with
1>        [
1>        ]
1>c:\users\james\desktop\dash\src\primitives/transaction.h(105): note: see reference to function template instantiation 'void SerReadWrite<Stream,CScriptBase>(Stream &,const T &,int,int,CSerActionSerialize)' being compiled
1>        with
1>        [
1>            Stream=CSizeComputer,
1>            T=CScriptBase
1>        ]
etc (removed so it's under the max chars)
1>c:\users\james\desktop\dash\src\compat.h(93): warning C4273: 'strnlen': inconsistent dll linkage
1>C:\Program Files (x86)\Windows Kits\10\Include\10.0.10240.0\ucrt\string.h(357): note: see previous definition of 'strnlen'
1>c:\users\james\desktop\dash\src\support/pagelocker.h(13): fatal error C1083: Cannot open include file: 'boost/thread/mutex.hpp': No such file or directory
1>Generating Code...
1>Done building project "TestCoin2.vcxproj" -- FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
