bootstrap.dat to help new clients to sync faster
That is cool! so you download the latest bootstrap.dat to the data folder, start normally the new wallet and sync time is much faster?
sounds good, is darkcoins any different to bitcoin's bootstrapping for example, could it use the masternodes as validation of authenticity?
I put this bootstrap.dat in the Darkcoin folder and I'm running the Testnet wallet, loading the blockchain but it doesn't seem to sync faster.
bootstrap.dat is simply blockchain files (blk*.dat) concatenated in one.
This bootstrap.dat is made from mainnet blockchain so it will not help you to sync on testnet.
Ah... and here I was hoping it could do both... lol.. Can you make one for Testnet? :)
Is this normal behavior when trying to sync using the bootstrap? Thanks
2015-03-18 11:30:39 ERROR: ProcessBlock() : already have block 225091 00000000000c951b112b43e0942a87f63db20826e1fb257ba6425a662254c969
2015-03-18 11:30:39 ERROR: ProcessBlock() : already have block 225092 00000000000aea42ec3af8d29291022cf40195ba2a5947e348a5325a18c72272
2015-03-18 11:30:39 ERROR: ProcessBlock() : already have block 225093 000000000006627dd2ee13fd6fef6aa32cddf3e5e5985047637769143273dc42
Yep, creating bootstrap is a pretty dumb procedure now - I'm not cleaning it from old chains (they are not that long comparing to main chain so I just save some time on that). There should be not too much of them as far as I know.
