Did you have deleted the peers.dat before you started the reindex process?
Do you use the client 110122? Is your wallet version 61000? What OS do you use?
So just to clarify, your steps for reindex are:
./darkcoind stop
rm peers.dat from the data folder
./darkcoind --reindex
Correct?
Then the reconverge with the spork is working network wide. There were explorers stuck on block 218963 that have since caught up and are on track again.Hm, blockcount changed to 207895)
P.S. And back to 207991
As workaround try some addnodes and download the blockchain from theseSo what I need to do?![]()
addnode=84.201.37.188
addnode=93.127.226.228
addnode=93.127.247.50
addnode=93.127.247.88
addnode=104.153.209.143
addnode=104.156.244.221
addnode=107.170.196.35
addnode=108.61.170.161
addnode=108.61.209.50
addnode=108.61.242.80
addnode=151.80.5.192
addnode=162.220.13.194
addnode=178.62.11.208
addnode=178.62.129.181
addnode=185.77.129.140
addnode=204.152.219.139
addnode=211.99.224.171
addnode=216.189.150.236
addnode=23.226.128.184
addnode=37.59.19.89
addnode=41.223.52.13
addnode=50.168.230.216
addnode=54.77.168.55
addnode=54.173.91.202
addnode=82.211.21.10
Doing it now!It seems there are still many nodes on the wrong (stuck) chain...
coingun may i ask you to update dnsseed.masternode.io to latest upstream @ https://github.com/nightlydarkcoin/darkcoin-seeder - thanks!
Code:addnode=84.201.37.188 addnode=93.127.226.228 addnode=93.127.247.50 addnode=93.127.247.88 addnode=104.153.209.143 addnode=104.156.244.221 addnode=107.170.196.35 addnode=108.61.170.161 addnode=108.61.209.50 addnode=108.61.242.80 addnode=151.80.5.192 addnode=162.220.13.194 addnode=178.62.11.208 addnode=178.62.129.181 addnode=185.77.129.140 addnode=204.152.219.139 addnode=211.99.224.171 addnode=216.189.150.236 addnode=23.226.128.184 addnode=37.59.19.89 addnode=41.223.52.13 addnode=50.168.230.216 addnode=54.77.168.55 addnode=54.173.91.202 addnode=82.211.21.10
Just created fresh bootstrap, should take you to block 219005.Same here
https://github.com/UdjinM6/darkcoin-bootstrap
