Anyone with a XFX r9 280x TD-FD ?
Discussion in 'Mining' started by alexlandon, Apr 14, 2014.
  1. alexlandon
    alexlandon New Member
    Apr 14, 2014
    Is Anyone here with a XFX r9 280x TD-FD ? if yes please post me your settings and the miner you use!
    I get 1.4 MH/s with it..
    THANKS in ADVANCE
  2. NameUser
    NameUser New Member
    Mar 28, 2014
    10
    The problem isn't necessarily related to your specific card. Post your config so we can check if there are any configuration issues. Also, which OS?
  3. fra55
    fra55 Member
    Mar 26, 2014
    143
    14
    68
    Yes post your config file or bat file and we can help you.
    Also post your gpu and memory clock speeds
  4. alexlandon
    Apr 14, 2014
    I'm using windows 7 ultimate 64-bit
    setx GPU_MAX_ALLOC_PERCENT 200
    setx GPU_USE_SYNC_OBJECTS 1
    color 0A
    sgminer.exe --kernel darkcoin -o stratum+tcp://stratum1.suchpool.pw:3335 -u u -p x -g 2 -w 256 --lookup-gap 2 --thread-concurrency 8192 --shaders 2048
  5. fra55
    fra55 Member
    Mar 26, 2014
    143
    14
    68
    Try with -g 1. Moreover, thread concurrency overlaps shaders, so put just one of the two.
    Personally, I use shaders, got better results
