P2Pool [ANN][CORE][11.01.25][SEATTLE] DRK02.P2POOLMINING.US
ourlink
237
65
188
Heartland, USA
www.p2poolmining.us
Darkcoin P2Pool Hosted via Vultr in Seattle
* format of the announcement copied from scorpio18's announcement because it is very clear and well written.
address: stratum+tcp://drk02.p2poolmining.us:7903 (or http://drk02.p2poolmining.us:7903)
Username: Your Darkcoin wallet address
Passoword: Does not matter, anything!
Status p2pool:
http://drk02.p2poolmining.us:7903/static
http://drk02.p2poolmining.us:7903/static/original
Node Information: Running Darkcoin Core Version 11.01.25, fee: 1.25% fee.
How to connect
First of all NO registration required. Payouts occur automatically as new blocks are found.
All you need to mine here is a Darkcoin address. Setup your mining software with these parameters:
SERVER: stratum+tcp://drk02.p2poolmining.us:7903 (or http://drk02.p2poolmining.us:7903)
PORT: 7903
USERNAME: Your Darkcoin wallet address
PASSWORD: x
DO NOT use an exchange deposit address as a username as it may not receive payments correctly. Use an address from a wallet you own!
For more details, such as example commands for cpuminer, ccminer and sgminer, share difficulty adjustment and calculation tutorial, please refer to this excellent post by scorpio18 (his/her p2pool node announcement).
Visit our blog at http://www.p2poolmining.us for updates and FAQ's
tuppydog
251
72
NC
XhyHv1cs4T54kD1HXVY7kYZMqo2Kg8hWu4
no problem, switched to Chicago, everything seems to be running well..! Let us know if you decide to go to 14, I'll update thank you...!
ourlink
237
65
188
Heartland, USA
www.p2poolmining.us
Not only does the P2PoolMining pools provide detailed statistics for your miner regarding hashrates and payouts... But did you know that you also have access to the Classic P2Pool Stats using the menu option under Performance Charts;
