401 Unauthorized Error
Discussion in 'Development Tech Discussion' started by Emin, Oct 17, 2017.
  1. Emin
    Emin New Member
    Oct 17, 2017
    Hi everyone,
    I am trying to connect dashd but it gives an error.
    When I looked ~/.dash/dash.conf everything is ok.
    I am running dashd with this command.
    Error: Cannot obtain a lock on data directory /root/.dashcore. Dash Core is probably already running.
    I am tried with php
    jsonRPCClient it gives HTTP request failed! 401 Unauthorized
    shell_exec gives no output
    Do you have any idea ? It caused headache.
    PHP:
                $output        shell_exec('curl --user dashUser:dashPass --data-binary \'{"jsonrpc": "1.0", "id":"curltest", "method": "getinfo", "params": [] }\' -H \'content-type: text/plain;\' http ://127.0.0.1:9998/');
    $res           json_decode($output);
    print_r($res);
    $Dash           = new jsonRPCClient("http ://user:[email protected]:9998/");
    $num     $Dash->getblockcount();
    print_r($num);
  2. akhavr
    akhavr Active Member
    Oct 11, 2014
    742
    375
    Looks like you've forgot to restart your `dashd` after you've added `rpcport` option. Stop it via `dash-cli stop` and then start again.
  3. Emin
    Emin New Member
    Oct 17, 2017
    I reboot my server but still not works.
    I installed dashd again via PPA and everything is ok now. (I had installed manually via wget)
    sudo add-apt-repository ppa:dash.org/dash
    sudo apt-get update
    sudo apt-get install dashd dash-qt
  4. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
  5. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
