Verificationprogress is decreasing
st3p
Hi all.
I downloaded Dash Core for Ubuntu. Then i started dashd. After several hours local blockchain
was synchronized. getblockchaininfo showed verificationprogress near 0.99999... Everything was good.
Then i changed config file by adding testnet=1. Blockchain started sync. Verificationprogress reached 0.94.. and then stared to decreasing. I tried to rescan, but it did not help. Then i removed all files from ./dashcore/testnet3, but it also did not help.
Then i changed config file by removing testnet=1. At first verificationprogress also started decreasing. Now it fluctuates.
Fluctuation of verificationprogress:
0.9999990769515745
0.9999951212299205
0.9999948575139751
0.9999871365587784
0.9999982565829589
0.9999979635722882
0.9999990916667763
0.9999977731214846
0.9999952678950098
getblockcount returns 759568
Is it normal? And maybe someone knows how to solve the problem with testnet.
Thank you for attention.
verificationprogress is an estimation which is not supposed to be 100% accurate, just ignore it.
