Using PHP and darkcoind
Discussion in 'Development Tech Discussion' started by calnaughtonjnr, Mar 24, 2015.
  1. calnaughtonjnr
    calnaughtonjnr Well-known Member
    May 25, 2014
    221
    157
    203
    Is there anything that can help me use php with darkcoind? Specifically, I need to generate wallet addresses.
    • Like Like x 1
  2. oblox
    oblox Well-known Member
    Aug 6, 2014
    1,032
    537
    You could always use the paper wallet generator that is an html-based doc for wallet generation with you importing the private key into darkcoind but why not go directly to the source and generate a new address intrawallet. What exactly are you doing?
  3. calnaughtonjnr
    May 25, 2014
    221
    157
    203
    A site I'm working on needs to have a wallet address for the user. It's hosted on a server with darkcoind running on it. I was hoping to run a command similar to
    darkcoind getnewaddress usersWalletAddr1
    ...but within a php script.
  4. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
    Try https://github.com/aceat64/EasyBitcoin-PHP
    I understand that it can also connect to darkcoind rpc as well.
    • Like Like x 1
  5. calnaughtonjnr
    May 25, 2014
    221
    157
    203
  6. calnaughtonjnr
    May 25, 2014
    221
    157
    203
    If anyone can help, I'm getting couldn't connect to host error. Is there anyway I can check what port number I should be connecting to in case it's not default?
    Also, should I be using the rpc username and password in my darkcoin.conf?
    Edit: I got it guys. Found a command to list open ports and used that. Running sweet now! :D:D:D:D
    #6 calnaughtonjnr, Mar 24, 2015
    • Like Like x 1
  7. jakehaas
    jakehaas Member
    Dec 9, 2014
    41
    29
    I could be wrong, but couldn't you just have the PHP execute a shell command to talk to the daemon?
