Stratum Host Setting (UNOMP related)
mearvk
Confused a little about the UNOMP config.json file. I know it's a UNOMP issue more basically however I'm left with a quick question which I think will be suitable. If this isn't the thread or subforum please do kindly feel free to move the question.
Looking at the UNOMP JSON config file I find there is a website:stratumHost setting. It defaults to pool.unomp.org. I'm not sure whether, in the case of Dash (the currency), if we should be using a default setting here. I've had a quick look and have found that test.stratum.dash.org is also sometimes used early in testing. Can it be verified if we should be using one particular setting (localhost, stratum.dash.org, etc) in the case of a particular currency and if so which?
Thanks.
Max
