Solo mining to one wallet from multiple PCs using CCMiner
bmoscato
I have a two part question/issue...
I'm trying to configure my PC to run CCMiner to localhost mining to my wallet. I tried mining directly to the wallet without changing the darkcoin.conf file, but that didn't work. I also started the wallet with the -server variable and it still didn't work. I tried no port as well as different range of ports...
CCMiner:
ccminer35-50.exe --algo=x11 -o stratum+tcp://127.0.0.1:9999 -u user -p x
pause
darkcoin.conf
rpcuser=user
rpcpassword=x
rpcallowip=127.0.0.1
rpcport=9999
daemon=1
server=1
gen=0
How do I mine to a wallet on my PC from CCMiner on my PC?
Can I mine to my wallet from other home computers by adding 'addnode=' or 'connect='?
bmoscato
Anyone? I'm totally lost here.
I changed my config file on the wallet to try localhost, the ip address of the PC, the external address of the PC...
darkcoin.conf:
rpcuser=user
rpcpassword=x
rpcallowip=192.168.0.25
rpcallowip=10.0.0.45
rpcallowip=208.253.161.x
rpcallowip=173.77.148.x
rpcallowip=ANYOTHERMINERS
rpcport=9999
server=1
daemon=1
listen=1
miner.bat:
ccminer30.exe --algo=x11 -o 192.168.0.25:9999  -u user -p x
pause
bmoscato
My response:
C:\Mining\ccminer\x86>ccminer30.exe --algo=x11 -o 192.168.0.25:9999 -u user
-p x
[2014-08-12 08:01:05] 1 miner threads started, using 'x11' algorithm.
[2014-08-12 08:01:05] H T P request failed: Empty reply from server
[2014-08-12 08:01:05] json_rpc_call failed, retry after 30 seconds
ryen123
12
7
CCMiner:
pause
darkcoin.conf
rpcuser=user
rpcpassword=x
rpcport=9999
daemon=1
server=1
gen=0
DarkCoin uses port 9999 and the default rpcport=9332. So inside your darkcoin.conf file should look like this
rpcuser=user
rpcpassword=x
rpcport=9332
daemon=1
server=1
Restart wallet after making changes to .conf file.
Then run your ccminer: ccminer35-50.exe --algo=x11 -o 127.0.0.1:9332 -u user -p x
