Solo Mining setup problem
Discussion in 'Mining' started by piK, Nov 25, 2015.
  1. piK
    piK New Member
    Nov 24, 2015
    7
    Hello folks,
    I have downloaded my wallet from dashpay and have this dash.conf setup on one computer (192.168.0.3).
    port=9998
    rpcuser=SoloMiningUser
    rpcpassword=SoloMiningPassword
    rpcallowip=127.0.0.1
    rpcallowip=192.168.0.1/255.255.255.0
    rpcport=9999
    server=1
    daemon=1
    listen=1
    gen=0
    I downloaded a cpu miner from github and running the miner from another computer (192.168.0.2) with the command
    minerd-corei7-avx.exe --algo=X11 --url=192.168.0.3:9999 --user=SoloMiningUser --pass=SoloMiningPassword --threads=8
    I'm getting the error: The requested URL returned error: 404 Not Found
    When I connect with Firefox on the URL I get the document:
    {"result":null,"error":{"code":-32700,"message":"Parse error"},"id":null}
    I get the same error when trying to launch CPU miner on the same computer as the wallet (192.168.0.3).
    What do I miss? Any help appreciated.
    #1 piK, Nov 25, 2015
  2. AndyDark
    AndyDark Well-known Member
    Sep 10, 2014
    353
    705
    163
    space before the "--threads=8" ?
    • Like Like x 1
  3. piK
    piK New Member
    Nov 24, 2015
    7
    Nah, happend with copy + pasting here as I changed the password.
    Is solo mining even possible? I read some topics on the forum here but I'm not sure what the current status is.
  4. Sub-Ether
    Sub-Ether Well-known Member
    Mar 31, 2014
    1,516
    1,254
    Yes and no.
    To clarify, if you are mining from a single wallet, it is possible, goto debug console and use the command setgenerate true
    Place a number at the end to lower the cores used by the processor such as 7 to leave 1 for browsing(set to false to turn off) this is a slow way of mining and is not optimized or recommended.
    What is not working is sgminer or an external cpu miner working together with the wallet to solo mine(no rpc/get work), it has been removed from the bitcoin source,it is hoped to bring it back (3 or 4 lines of code need removing) but it not a priority for github atm.
    The good news is nicehash offer solo mining, you can do it from there, just change the .bat setting in my guide and select your minerd :)
    https://solo.nicehash.com/
    use my small cpu guide for the best cpu miner from here,
    https://dashtalk.org/threads/sub-ethers-guide-to-cpu-mining.6170/
  5. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    For nicehash put something like this in your .bat command,
    minerd-corei7-avx.exe -a X11 --url stratum+tcp://stratum.solo.nicehash.com:3336 -u XpqhTM2WKWJrMqn48icsNZKiPuQ8MFEnSp -p x -t 8
    pause
  6. piK
    piK New Member
    Nov 24, 2015
    7
    Thank you very much for clarifying this. +1
    #6 piK, Nov 25, 2015
    • Like Like x 1
  7. piK
    piK New Member
    Nov 24, 2015
    7
    NiceHash is a very nice option. Thank you very much for the hint!
    • Like Like x 1
  8. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    I may add that I tried 8 megahash GPU solo mining for 4 days and got nothing, others say they have been more fortunate, am thinking you will need at least 20 meg to stand a regular chance of finding a block, so good luck!
  9. piK
    piK New Member
    Nov 24, 2015
    7
    But does it really mather if you are hashing 2M or 20M? I thought the chance are pretty equal. I will give it a try for a couple of days.
  10. Rabinovitch
    Rabinovitch Member
    Mar 29, 2016
    13
    68
    Not really. These are my 2 Baikals 150 MH mining in solo at Nicehash for 2 days or so. What's up with hashrate?.. Everything is OK at Baikals' side.
    [​IMG]
  11. Cryptopool.io
    Cryptopool.io New Member
    Jan 8, 2017
    32
    9
