Sentinel does not work, could it be the cause of ban?
johnyj
16
Since two weeks ago my mn is not active until I noticed it recently,
And after upgrade to 18.0.1 my mn still not work
Python 2.7 is not supported
And when I tried to update sentinel, another error appeared:
Downloading/unpacking deprecation==2.1.0 (from -r requirements.txt (line 1))
Cannot fetch index base URL https://pypi.python.org/simple/
Could not find any downloads that satisfy the requirement deprecation==2.1.0 (from -r requirements.txt (line 1))
Cleaning up...
No distributions at all found for deprecation==2.1.0 (from -r requirements.txt (line 1))
Storing debug log for failure in /home/johny/.pip/pip.log
Is it so that if sentinel is not working, then mn is banned?
If I run dash-cli masternode status, it shows everything ok, but if I run dash-cli mnsync status
"IsBlockchainSynced": false,
"IsSynced": false
splawik21
Yeah, it's me....
Apr 8, 2014
1,965
1,327
What getblockchaininfo command gives you as a. response?
darkness
46
10
For the python error, this is what I did:
1) Delete sentinel directory
2) apt install python virtualenv
3) Reinstall sentinel
Then it just worked... (before this I had stupidly installed python3 so I uninstalled that and then did these steps).
Also, if you want to redo the blockchain you can delete the "mncache.dat" file.
johnyj
16
I get error: Unable to locate package virtualenv
johnyj
16
"chain": "main",
"blocks": 1738697,
"headers": 1738697,
"bestblockhash": "00000000000000362d528545b40976af8a9b5380def57d63943a30a9379a5385",
"difficulty": 73244017.95390324,
"mediantime": 1663244460,
"verificationprogress": 0.9992588674192312,
"initialblockdownload": true,
"chainwork": "000000000000000000000000000000000000000000007871309887ec28a6e90a",
"size_on_disk": 31201501757,
"pruned": false,
"softforks": [
"id": "bip34",
"version": 2,
"reject": {
"status": true
qwizzie
2,016
1,185
These are normally the commands to install Sentinel (either as new or after having deleted the Sentinel folder) :
cd ~/.dashcore
cd sentinel
virtualenv venv
And this is the command to just update the Sentinel version from there on out :
cd .dashcore/sentinel
git pull
And yes, Sentinel not working will cause a PoSe ban.
Also having
"IsSynced": false
indicates a sync problem. Check this article for problem solving, if you keep having a sync problem as well : https://dev.to/dcgcrew/dash-core-v18-whats-new-4a3d
johnyj
16
cd ~/.dashcore
cd sentinel
virtualenv venv
It is this command brings the error:
Cleaning up...
And in the log:
venv/bin/pip run on Sat Sep 17 21:08:24 2022
Getting page https://pypi.python.org/simple/deprecation/
Could not fetch URL https://pypi.python.org/simple/deprecation/: 403 Client Error: SNI is required
Will skip URL https://pypi.python.org/simple/deprecation/ when looking for download links for deprecation==2.1.0 (from -r requirements.txt (line 1))
Could not fetch URL https://pypi.python.org/simple/: 403 Client Error: SNI is required
Will skip URL https://pypi.python.org/simple/ when looking for download links for deprecation==2.1.0 (from -r requirements.txt (line 1))
URLs to search for versions for deprecation==2.1.0 (from -r requirements.txt (line 1)):
* https://pypi.python.org/simple/deprecation/2.1.0
Getting page https://pypi.python.org/simple/deprecation/2.1.0
Could not fetch URL https://pypi.python.org/simple/deprecation/2.1.0: 403 Client Error: SNI is required
Will skip URL https://pypi.python.org/simple/deprecation/2.1.0 when looking for download links for deprecation==2.1.0 (from -r requirements.txt (line 1))
I think this is a python problem but so far did not find a solution to it, and why it worked last month? Something must have changed in the latest sentinel update that broke this
johnyj
16
sudo apt-get update
sudo apt-get install virtualenv
I get this
# apt-get install virtualenv
Reading package lists... Done
Building dependency tree
E: Unable to locate package virtualenv
Some posts on stackoverflow says the package is called python-virtualenv, that is already installed
The node is running an old ubuntu 14.04, but it rans well until two weeks ago
johnyj
16
"IsSynced": false
Thanks, after invalidate and reconsidered the block 1737792, now it syncs with the latest block, but sentinel could not run due a problem with python, it says does not support python 2.7, and after I compiled the latest python 3.10, it can not generate venv, saying the package virtualenv could not be located
AgnewPickens
Chief Sock Advisor
Mar 11, 2017
608
315
I get this
I think v18 needs a newer Linux Distro than 14.04, a lot of users are using Linux 20 distros, think there may be some things missing from 14.04 that v18 needs.
johnyj
16
Maybe, but now it seems only a sentinel problem with configurations in python, the node itself syncs fine now after refreshed the forked block 1737792
Do you really need sentinel or it is just for self-monitoring purpose? I can see my mn now on both dashninja and DC
AgnewPickens
Chief Sock Advisor
Mar 11, 2017
608
315
Not sure how important Sentinel is, but there have been other issues with Linux Distros, 22.04 dropped some libraries V18 needed and that caused some problems. Glad you have it syncing, I am am not a masternode owner, so maybe somebody else can answer that last question. @xkcd ?
Reactions: xkcd
johnyj
16
I managed to update the pip to version 20.3.4 and then pip command become this:
~/.dashcore/sentinel# venv/bin/pip install -r requirements.txt
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Collecting deprecation==2.1.0
Downloading deprecation-2.1.0-py2.py3-none-any.whl (11 kB)
ERROR: Could not find a version that satisfies the requirement packaging==21.3 (from -r requirements.txt (line 2)) (from versions: 14.0, 14.1, 14.2, 14.3, 14.4, 14.5, 15.0, 15.1, 15.2, 15.3, 16.0, 16.1, 16.2, 16.3, 16.4, 16.5, 16.6, 16.7, 16.8, 17.0, 17.1, 18.0, 19.0, 19.1, 19.2, 20.0, 20.1, 20.2, 20.3, 20.4, 20.5, 20.6, 20.7, 20.8, 20.9)
ERROR: No matching distribution found for packaging==21.3 (from -r requirements.txt (line 2))
And after checking the requirements.txt, these are the files that pip can not install, marked with *. I tried manually install each of them
deprecation==2.1.0
packaging==21.3*
peewee==3.14.10
py==1.10.0
pycodestyle==2.4.0
pytest==7.0.1 *
pyparsing==3.0.9 *
python-bitcoinrpc==1.0
simplejson==3.8.2
darkness
46
10
Radical plan, but just to make sure you have the right python...
1) sudo apt remove python2
2) sudo apt autoremove --purge
3) python --version (you should get nothing because it's uninstalled - if it says version 3 then get rid of that too)
4) sudo apt update
5) sudo apt install python2 python
xkcd
453
430
australia
mnowatch.org
Ubuntu 22 LTS is now supported, the issue impacting was recently resolved. The OP is recommended to re-install the OS, eg Ubuntu 22 LTS and then run the Dash Masternode Zeus for clean operations.
Reactions: AgnewPickens
johnyj
16
What is the purpose of sentinel? Can you just remove it?
I remember that sentinel was there for old masternode architecture, but after the dip3 change, the way how masternode works has greatly changed, is there still a need for sentinel?
I have been running it for 12 hours without sentinel working, the node still syncs without problem and registered on mn list
qwizzie
2,016
1,185
Lets hope a dev jumps in with regards to possible missing supportive libraries in 14.04, causing a failed Sentinel installation with Dash Core v18.0.1
You can raise a github issue about it here : https://github.com/dashpay/dash (that should get the attention of the devs)
Also you could upgrade your system to 18.04.6 LTS and see if that fixes things with Sentinel.
I am running that OS version without a problem with regards to Sentinel so far. I do remember seeing that deprecation notice of Python 2.7 but it does not throw an error and installs fine.
I worry that over time you will end up with PoSe scores, when Sentinel is not active.
xkcd
453
430
australia
mnowatch.org
Sentinel is not required.
johnyj
16
I really think that is just a configuration problem, since I have other services running on that 14.04 machine, it will impact lots of other legacy environments if I upgrade the OS, so I hope that just by installing the required package, the sentinel.py could run.
Now the sentinel.py just throws "Python 2.7 is not supported", but it seems it works on your machine, that's odd
